I’m getting an error when I try to run workflows in parallel mode (rlaunch multi) on Windows. I’m running Python 3.6.2 and Fireworks 1.4.8 inside a Conda environment on Windows 10. This is clearly related to the multiprocessing lib in python and differences between Windows and Unix. I have also reproduced the same error by calling **fireworks.features.multi_launcher.launch_multiprocess **from a python script. I have tried the same on Ubuntu 16.04 (identical environment), where everything works fine.
I have seen little evidence that Windows in fact is a target platform for Fireworks, but is the parallel-processing functionality something you would consider adapting to work on Windows as well?
Alternatively I’m looking for advice for workarounds for running workflows in parallel in ‘infinite’ mode.
Here is the traceback when issuing “rlaunch multi 2” on the command-line:
(tailor_py3) C:\Users\audun>rlaunch multi 2
2017-08-07 12:42:44,404 INFO Hostname/IP lookup (this will take a few seconds)
File “c:\users\audun\miniconda2\envs\tailor_py3\lib\runpy.py”, line 193, in _run_module_as_main
“main”, mod_spec)
File “c:\users\audun\miniconda2\envs\tailor_py3\lib\runpy.py”, line 85, in run_code
exec(code, run_globals)
File "C:\Users\audun\Miniconda2\envs\tailor_py3\Scripts\rlaunch.exe_main.py", line 9, in
File “c:\users\audun\miniconda2\envs\tailor_py3\lib\site-packages\fireworks\scripts\rlaunch_run.py”, line 148, in rlaunch
local_redirect=args.local_redirect)
File “c:\users\audun\miniconda2\envs\tailor_py3\lib\site-packages\fireworks\features\multi_launcher.py”, line 189, in launch_multiprocess
ds = DataServer.setup(launchpad)
File “c:\users\audun\miniconda2\envs\tailor_py3\lib\site-packages\fireworks\utilities\fw_utilities.py”, line 203, in setup
m.start()
File “c:\users\audun\miniconda2\envs\tailor_py3\lib\multiprocessing\managers.py”, line 513, in start
self._process.start()
File “c:\users\audun\miniconda2\envs\tailor_py3\lib\multiprocessing\process.py”, line 105, in start
self._popen = self._Popen(self)
File “c:\users\audun\miniconda2\envs\tailor_py3\lib\multiprocessing\context.py”, line 322, in _Popen
return Popen(process_obj)
File “c:\users\audun\miniconda2\envs\tailor_py3\lib\multiprocessing\popen_spawn_win32.py”, line 65, in init
reduction.dump(process_obj, to_child)
File “c:\users\audun\miniconda2\envs\tailor_py3\lib\multiprocessing\reduction.py”, line 60, in dump
ForkingPickler(file, protocol).dump(obj)
AttributeError: Can’t pickle local object ‘DataServer.setup..’
File “”, line 1, in
File “c:\users\audun\miniconda2\envs\tailor_py3\lib\multiprocessing\spawn.py”, line 105, in spawn_main
exitcode = _main(fd)
File “c:\users\audun\miniconda2\envs\tailor_py3\lib\multiprocessing\spawn.py”, line 115, in _main
self = reduction.pickle.load(from_parent)
EOFError: Ran out of input
Any help is much appreciated,
Regards,
Audun Gravdal Johansen
