Hello
Does anyone know how I can run LAMMPS parallel-wise in windows 7?
I use a processor of the type:
Intel® Core™2 Duo CPU P8700 @ 2.53GHz 2.53 GHz
Thank You.
Hello
Thank You.
It runs fine with MPICH2, so you will need to properly install that. Once that is done, here is a script I use to run it.
—lammps_mpi.bat—
@echo off
set MPIEXEC=“C:\Program Files (x86)\MPICH2\bin\mpiexec.exe”
set LAMMPSEXE=C:\local\bin\lmp_win_mpi.exe
set N=%1
set INFILE=%2
set LOGFILE=%3
MPIEXEC -n %1 -noprompt LAMMPSEXE -in %2 -log %3 -var RANDSEED RANDOM
