All,
I have a membrane that is adhered to a rigid surface (fix wall LJ/93) and using the command “indent” I apply a normal load, and then set the spherical indenter to sliding (think rigid AFM tip). The tip slides for a while, but eventually I get the error: “Particle on or in fix wall surface”, which seems a bit unusual since the indenter is sliding laterally along the membrane and not pushing atoms further down to cross the fix wall surface.
Is there a way to prevent this from occurring or to prevent the code from crashing when this happens?
-Emil
