Hello everyone!
I’m trying to simulate the motion of particles in a granular system. First I define the “dimension” to be 2, I make a box whose length in Z direction is much shorter than in X and Y direction. Then I used the “fix pour” command to pour particles in. The code can run but I cannot see any particle in OVITO. I check the dump file, and find that coordinate of all particles are nan. I don’t know why.
However, I change the dimension to 3 and it works, but I doubt if it is the real 2d simulation.
This is my code. I can’t upload file because I’m a new user. Sorry for that.
units lj
atom_style sphere
dimension 2
comm_modify vel yes
region box block -200 200 -200 200 -0.75 0.75 units box
create_box 2 box
pair_style hybrid gran/hooke 4000.0 NULL 100.0 NULL 0.5 1
pair_coeff * * gran/hooke
region container block -180 180 -180 180 -0.75 0.75 units box
fix container all wall/gran/region hooke/history &
4000.0 NULL 100.0 NULL 0.5 1 region container
neighbor 0.3 bin
fix 1 all nve/sphere
fix 2 all gravity 1.0 vector 0 0 -1
fix 3 all pour 500 1 123456 region container ignore vol 0.86 10 diam poly 2 1.0 0.5 1.4 0.5
timestep 0.05
compute 1 all temp
compute_modify 1 dynamic/dof yes
compute 2 all temp/sphere
compute_modify 2 dynamic/dof yes
thermo 100
thermo_style custom step atoms temp c_1 c_2 press
thermo_modify lost ignore
compute_modify thermo_temp dynamic/dof yes
dump 1 all atom 50 dump1.example
run 500
