I am trying to install and use kim-api-v.1.9.3, following information
on https://openkim.org/kim-api/.
In 'Installing KIM Models' it says you should do
$ kim-api-v1-collections-management install system --sudo Three_Body_Stillinger_Weber_Si__MO_405512056662_003
but this requires Password. (Prompt like "Enter Password : " appears.)
How can I get the password?
When you use the "--sudo" option the utility will do something like
sudo make install
So the password that is being requested is the one that would be necessary to execute the above "sudo" command. This is typically the password for the user account that is executing the command.
If you happen to be do this all on a virtual machine, and in particular using vagrant, then you would typically be logged in as user-name "vagrant" which, by default will have a password of "vagrant".
Sorry it is not working. The "Enter Password" prompt is coming from the kim-api-v1-collections-managment utility, which uses what you enter to do various "sudo xxxx" commands. So, it should be the user account password that is needed... What does the utility say after you enter a password?
Anyway,...
You can always install your models to the "User Collection", which should not need any passwords. Just use this command instead of the original:
$ kim-api-v1-collections-management install user Three_Body_Stillinger_Weber_Si__MO_405512056662_003
When I do
I get
Enter Password :
I type my user account password, then I get
[sudo] password for umeno:
then the following message appears.
Bad password.
Aborting!
I found that getting around this problem is possible simply
by doing 'install system' as root, but I'd feel more comfortable
with doing it by sudo.
Thanks for the tip! If I cannot solve the above problem
I'll live with this, but I just think the way in the quick guide
in https://openkim.org/kim-api/ should work..
you can see the code for how the utility is trying to execute the sudo command at the point that you are having trouble.
I am happy to continue to work with you to figure this out. If this is a problem that other users would run into, I would like to find a fix that we can include in the utility...
The utility uses the "-k" and "-S" command line options to sudo. It looks like
maybe your version of sudo does not support these?
Uh, you are right! On my system, strangely, sudo I was executing is just a wrapper
to the actual sudo, so 'sudo -k -S' does not work properly (the wrapper cannot
handle the options).
I am on CentOS6.9 and the wrapper came with devtoolset-1.1-runtime-1-13.el6.noarch
which was needed to upgrade gfortran by devtoolset-1.1-gcc-gfortran-4.7.2-5.el6.x86_64
(to let it coexist with its older version).
I don't know whether this is a possible pitfall some people may fall in,
or it's just that my system is a freak.
Anyway, thanks for your kind support to help me out!
