Hello all,
I have a system that involves different kinds of atoms and molecules. I want to continue my previous runs from the last restart file to compute the velocity of each atom/molecule in my system. The problem is that I didn’t assign molecule IDs to monatomic molecules in my data file and consequently I can’t use a molecule style in chunk command. Is there any other way?
I will be grateful if you could help me.
Best
Hello all,
you can output per-atom velocities in a custom dump style as vx, vy
and vz properties.
velocities are also present in a separate data file sections, if you
convert a restart file into a data file.
Dear Axel,
Thanks for your answer. But I want per atom velocities which are averaged over the time and I think the two ways you suggested do not provide such values.
Dear Axel,
values.
http://lammps.sandia.gov/doc/fix_ave_atom.html
