I study stress on a beam with lps method. I defined a sc organisation and the studied volume is a cube on one side lattice. I applied two linear movements on each extremity.
I get negative value for the stress and values are too low compared to usual values. After a lot of searches, i didn´t succeed in solving this problem. Do you have any explanations ?
Thanks you for your consideration
Simon
Input File :
# 3D peridynamic simulation for traction
units nano
boundary s s s
atom_style peri
atom_modify map array
neighbor 0.1 bin
lattice sc 0.3615
#define all the parts
region beam block 0 36.15 0 2.169 0 2.169 units box
create_box 1 beam
create_atoms 1 region beam
region leftbc block 0 1.5337 0 2.169 0 2.169 units box
group leftbc region leftbc
region rightbc block 34.6163 36.15 0 2.169 0 2.169 units box
group rightbc region rightbc
group boundary union leftbc rightbc
group middle_atoms subtract all boundary
pair_style peri/lps
pair_coeff * * 140000 48000 5 50 0.01
set group all density 8960e-6
set group all volume 0.047241
compute peratom middle_atoms stress/atom NULL
compute sigmaxx middle_atoms reduce sum c_peratom[1]
variable sigmavolxx equal c_sigmaxx/vol
fix 1 rightbc move linear 3.615 0 0 units box
fix 2 leftbc move linear -3.615 0 0 units box
timestep 0.005e-3 #0.005
thermo 100
thermo_style custom step v_sigmavolxx lx
dump 1 all custom 5000 project_6_peri_metal_res.txt id x y z
dump_modify 1 append yes
run 5000
# SIMULATION DONE
print "All done"
