Phase Diagram Calculation using Phb command
I used maps to build the cluster expansion and constructed the convex hull successfully. Now I’m using phb to generate the phase diagram, but the command gets stuck at:
Looking for phase transition…
I believe this means the system has reached a region of metastability, but I’m not sure how to proceed.
Should I use phb with one GS and one disordered phase, or two GS structures? What’s the best way to handle this situation?
Typically, this could happen if the two phase equilibrium changes to a 3-phase equilibrium. Then you could restart the code with the current conditions (T,mu) but pick 2 of the three phases to continue. Often the new phase is the disordered state (e.g. -gs1=-1 ).
But I’d need to see the output to diagnose the problem for sure.
