phb issues while generating phase diagram
Hi Axel and everyone,
I am trying to generate a phase-diagram of binary BCC Cu-Pd system. I am getting some errors that I have not encountered before in ATAT.
When I use the following command, after printing two lines the ATAT seems to get stuck (I have attached the input and output files) and does not do anything.
phb -gs1=0 -gs2=1 -dx=.0100 -dT=10 -ltep=1e-3 -er=16 -o=phb.txt -k=8.617e-5 > output-phb.txt
Next, when I try to increase the cell size by ‘phb -gs1=0 -gs2=1 -dx=.0100 -dT=10 -ltep=1e-3 -er=20 -o=phb.txt -k=8.617e-5 > output-phb.txt’ I get the following error:
‘Missing sites in user-specified initial configuration (-is option)’
My suspicion is probably my input files are not correct but I am not fully sure where I am doing the mistake. If anyone can help that would be much appreciated!
Tanmoy
Sorry, can you paste in your input files. The attachment feature does not seem to work right now.
Ahh, sorry! I didn’t notice that earlier either. Here are my files, Thanks!
lat.in:
3.01989871153 3.01989871153 3.01989871153 90 90 90
-0.5 0.5 0.5
0.5 -0.5 0.5
0.5 0.5 -0.5
0 0 0 Pd,Cu
gs_str.out:
3.019800 0.000000 0.000000
0.000000 3.019800 0.000000
0.000000 0.000000 3.019800
-0.5 0.5 0.5
0.5 -0.5 0.5
0.5 0.5 -0.5
0.000000 0.000000 0.000000 Pd
end
  1. 0 0
    0 1. 0
    0 0 1.
    0.000000 0.000000 0.000000 Cu
    0.500000 0.500000 0.500000 Pd
    end
-0.5 0.5 0.5
0.5 -0.5 0.5
0.5 0.5 -0.5
end
eci.out:
-0.05709
-9.81E-04
0.01386
-0.00136
0.00354
-7.52E-05
1.35E-04
5.08E-04
-8.76E-04
-0.00376
-0.00179
-0.00172
-2.28E-04
clusters.out:
1
0.000000
0
1
0.000000
1
6
2.687006
2
-0.000000 0.500000 -0.500000
3
3.800000
2
-1.000000 0.000000 0.000000
12
4.654031
2
-1.000000 -0.500000 0.500000
6
5.374012
2
0.000000 -1.000000 1.000000
12
6.008328
2
-0.500000 -1.500000 0.000000
4
6.581793
2
-1.000000 -1.000000 1.000000
24
7.109144572
2
-1.500000 -1.000000 -0.500000
3
7.600003468
2
-2.00000 0.000000 0.000000
6
8.061021126
2
-1.50000 -1.500000 0.000000
12
8.061021126
2
-2.000000 -0.500000 -0.500000
12
8.497056566
2
-2.000000 -1.00000 -0.000000
output-phb.txt:
Phase 1 size: 19 19 19
Phase 2 size: 20 20 20
0 -0.110223 -1.000000 0.000000 -0.143807 -0.143807
phb.txt:
Your cluster.out seems to have been generated from another structure.
For instance, the pair cluster
6
2.687006
2
has the site "-0.000000 0.500000 -0.500000" which is not a bcc site.
BTW, I checked this by running the command:
corrdump.exe -s=gs_str.out  -c
and seeing that the code crashes while outputting the 3rd cluster.
-Axel
Ok, thanks Axel for pointing out the error. Here are my new ‘clusters.out’ file below. Could you please check my ‘gs_str.out’ file once? I am not fully sure if I wrote the CuPd structure (the middle one in the gs_str.out) correctly. Does it represent a bcc 50% (B2) structure for that lat.in or need to modify? My ‘lat.in’ is the correct one but I made ‘by-hand’ the ‘gs_str.out’ file, that’s why my confusion arises.
Secondly, after using this ‘cluster.out’ file together with previously mentioned files it seems working (at least giving some data - we need to check whether it makes sense later) when I use ‘phb -gs1=0 -gs2=1 -dx=.0005 -dT=1 -ltep=1e-3 -er=20 -o=phb.out -k=8.617e-5 > output-phb.txt’ but if I try to increase the cell size say, -er=20, ATAT tells me Missing sites in user-specified initial configuration (-is option). If I go to even higher cell size say, -er=30 it tells me ‘Bus error: 10’.
1
0.00000
0
1
0.00000
1
0.50000 0.50000 0.50000 0 0
4
2.61531
2
-0.00000 -0.00000 1.00000 0 0
3
3.01990
2
0.50000 0.50000 1.50000 0 0
6
4.27078
2
-0.50000 0.50000 1.50000 0 0
12
5.00794
2
-1.00000 -0.00000 0.00000 0 0
4
5.23062
2
1.50000 1.50000 1.50000 0 0
3
6.03980
2
-1.50000 0.50000 0.50000 0 0
12
6.58172
2
-1.00000 1.00000 -1.00000 0 0
12
6.75270
2
-1.50000 -0.50000 0.50000 0 0
12
7.39721
2
1.50000 2.50000 1.50000 0 0
12
7.84593
2
-0.00000 3.00000 0.00000 0 0
4
7.84593
2
-1.00000 -1.00000 -1.00000 0 0
6
8.54156
2
0.50000 2.50000 2.50000 0 0
24
8.93298
2
-1.00000 -0.00000 3.00000 0 0
Your ‘gs_str.out’ file seems ok.
If it says "missing sites" I suspect your cluster.out is still not quite right.
Did you try corrdump.exe -s=gs_str.out -c ?
Maybe recompile the code after changing the following lines in atat/src/makefile
CXXFLAGS=(PATCHCXXFLAGS) -DDEBUG -g #-DDEGE_GS #CXXFLAGS=(PATCHCXXFLAGS) -O3
(only one of the CXX… lines should be uncommented).
This will give an error message if bound checks are violated at run time.
