Phonon Dynamic matrix
Dear users,
I am try to calculate Dynamic matrix by LAMMPS , by moving the atoms at ( ±x,±y,±z ) direction by using the following equation
But the phonon transmission going to zero ,
Anyone can help me to find the coupling matrix of the reference cell to its two neighbouring cells in a wire as shown below
With best wishes,
Alaa,
image001.emz (7.76 KB)
This tool may make the task simpler, if you aren’t constrained to only using LAMMPS.
https://nanochemistry.curtin.edu.au/gulp/overview.cfm
Respectfully,
Dear Casimir,
Thank you for your message,
I fact I wrote Fortran code to greate dynamic matrix 3n x 3n where n no. of atoms by using the LAMMPS output file by using the flag “displace_atoms atom_i6 move 0.01 0.00 0.00 units box
dump 1 g2 custom 1 dump_i6xp.fc id type fx fy fz
dump_modify 1 sort id
dump_modify 1 format “%d d .12f .12f .12f”
run 0”
I think the tools that you indicate more complicate
Cheers,
Alaa,
Dear users,
+-x,+-y,+-z ) direction by using the following equation
​why not use fix phonon?
​axel.​
Dear Axel ,
I am never use fix phonon , and I think it is difficult to use it .
Alaa,
Dear Axel ,
if you don't want to use existing functionality, and also don't know how
to follow through on your me​thod of choice, then you are out of luck.
Dear axel,
The Idea I want to make compare between LAMMPS and DFT ,for example I got force constant by lammps and force constant by DFT (siesta). my job is which one more accuracy , I think it is difficult to use DFT in fix phonon
If you have any other idea help me
Cheers,
Alaa,
Dear axel,
​you are not making much sense here. ​it is obvious that your problem is
not as such a LAMMPS problem, but seems to be more a problem of
understanding what you are doing. nobody here is likely to do your job for
you and just hand you the answer.
​i don't know how to help people that don't make sense to me.
Many thanks Axel,
