Hello Friends,
Can someone suggest me a way to get the physical and chemical properties of various elements (like atomic mass, atomic number, ionic radii, atomic radii, Electronegativity, Ionization energy, Oxidation states, electric and thermal conductivity, density and so on from Materials Project. The matminer featurizer gives me some of the values …but they are material specific and not element specific. Further it gives only the min, max , average …etc of all the elements in the material
Thanks in advance
Hi @medackan, did you already consult our documentation? Are there any specific questions that the examples in our docs don’t cover?
Hello Tschaume,
I could not find an API link to get the properties like atomic radius, atomic mass, mass of proton, electronegativity, melting point, boiling point, thermal conductivity, valence numbers, oxidation states, and so on of various elements. Please help.
please suggest me a code or the functions that will help me in getting these values for all the elements in the periodic table
Hey @medackan: a lot of these values are in pymatgen, for example:
from pymatgen.core import Element
import pandas as pd
df = pd.DataFrame([[ele.name, *[getattr(ele,k,None) for k in ("atomic_mass","atomic_radius","ionic_radii","van_der_waals_radius")] ] for ele in sorted(Element,key = lambda k : k.Z)],columns=["Element","atomic_mass","atomic_radius","ionic_radii","vdw_radius"])
For oxidation states, there are some tools in pymatgen but you probably want to use a resource like the ICSD
