Dear all user
I want to plot scatter of the positions of two type atoms.
How can I do it?
I tried found in VMD but I did not find any option.
Best wishes
Mohammad
Dear all user
How can I do it?
Best wishes
Mohammad
Hi Mohammad, are the atoms of the two types in paired sets? A scatter plot implies that the coordinates come in pairs (x1, y1), (x2, y2), …
The dump command can be defined multiple times, e.g. a different one for each group that you select:
https://lammps.sandia.gov/doc/dump.html
Giacomo
Dear Giacomo
Thanks for replying to me.
I use this code to dump a snapshot of positions of atoms
write_dump all custom tragectory9.lammpstrj type x y z
Also, I use to try to dump each group of atoms in a separate file but I want to try dump in one file because I need to develop several types of atoms.
best wishes
It’s possible to make scatter plots of atom positions quite easily in OVITO (https://www.ovito.org/). Load your dump file in OVITO and then under “Add modification”, click “scatter plot”. From there you can select the properties you wish to plot.
