I’ve installed lammps-7Aug19 and linked it with PLUMED(2.4) in ‘static’ mode by first installing it in ‘lib/plumed’ directory. for the Plumed, I used ‘CXX=mpiicc, CC=icc’ and for lammps I used ‘icc_mpich’. The installation process completed successfully.
But while tring to submit the job, it is showing the following error
‘error while loading shared libraries: libblas.so.3: cannot open shared object file:’
I’ve no idea where the problem is occurring. need help.
Maybe the question is very silly, but our system administrator has no clue either, so I have to ask here.
-best
Radhika.
your executable is linked to this shared library, but it seems it is not installed on the compute node.
you can verify the path(s) to the required shared libraries with: ldd ./lmp_icc_mpich
get a better qualified system administrator. this is something a sysadmin should know.
