Dear lammps users,
After getting not acceptable results from fix smd, I tried colvars to calculate the PMF and work of desorption of a molecule from surface through steered molecular dynamics. I established my input file using the mailing list and the lammps example for ColVars.
The problem is that:
1- The output file of ColVars after simulations only contains the number of steps and nothing else! Other lammps outputs are fine.
2- The molecule does not move from the surface to the target point specified.
The input file of ColVars is as follows. I don’t know where I am making the mistake…
Thanks a lot for your suggestions.
