Dear LAMMPS users and developers,
I am trying to run an example of a “degenerate” rounded/polyhedron consisting of a single sphere.
I am on Ubuntu 22.04.4 LTS, LAMMPS (2 Aug 2023 - Update 2).
Upon executing lmp -in in.sphere
I get: ERROR on proc 0: Inconsistent face data for body of atom 1 (BODY/pair_body_rounded_polyhedron.cpp:588)
What am I doing wrong?
Here is the in.sphere:
units lj
atom_style body rounded/polyhedron 1 1
read_data data.sphere
variable cut_inner equal 1
variable k_n equal 100
variable k_na equal 0
variable c_n equal 0
variable c_t equal 0
variable mu equal 0
variable delta_ua equal 1
pair_style body/rounded/polyhedron ${c_n} ${c_t} ${mu} ${delta_ua} ${cut_inner}
pair_coeff * * ${k_n} ${k_na}
comm_modify vel yes
neighbor 0.5 bin
timestep 0.01
fix 1 all nve/body
thermo_style custom step ke pe etotal
thermo 1000
run 10000
a) please see the forum guidelines for correctly typesetting data from files
b) in case of problems running LAMMPS, please always report which LAMMPS version you are using and what platform you are running on (also mentioned in the guidelines)
c) in order for somebody to reproduce and debug your issue, you also need to provide the matching input file and let us know your command line.
Bottom line, the easier and less effort you make it to investigate and reproduce your issue, the better your chance to get meaningful help instead of people reminding you what you should be doing when asking about issues.
For N = 1 or 2, […] E and F are ignored and no edges or faces are listed […]
I have assumed that any value of E and F will do. However, on LAMMPS 7 Feb 2024 - Update 1 I obtain the same error with the original data file, but it works with E,F = 0:
Bodies
1 3 10
1 0 0
0.9 0.9 0.9 0 0 0
0 0 0
1.0
I wouldn’t say it is a bug, but it’s certainly confusing.
It is a bug. There is an internal function that returns the number of faces of the body, but with fewer than 3 vertices, there cannot be any faces and this function must return the proper value regardless of what it listed in the data file.
