Hi, everybody. I want to simulate jamming of semiflexible polymers using a Stillinger-Lubachevsky-like growth algorithm. The monomers will have some short-ranged, purely repulsive pair potential (e.g. pair_style gran/hooke), harmonic bonds (bond_style harmonic), and harmonic angular interactions (angle_style harmonic).
The question I have is how to implement the S-L particle-growth algorithm for this potential. In S-L, the particle diameters start out small, then increase with time at some defined rate. Can this be implemented in LAMMPS scripts using some sequence of commands involving “variables”? For example, by defining a variable corresponding to particle diameter and then telling LAMMPS it should increase at some defined rate? I think this can be done in stock LAMMPS, perhaps using “atom”-style variables for particle radius and mass, but am not sure how to do this.
Also, one potentially tricky issue for simulating polymer jamming is that the bond and angle interactions also need to “know” about the increasing monomer (particle) diameter. Can LAMMPS do this in its current form?
As always, any advice will me much appreciated :).
please have a look at fix adapt. this is meant to be the generic
mechanism to change simulation parameters over time. it may be needed
to add corresponding interfaces to specific styles, if needed, but the
procedure is usually rather straightforward.
Also, one potentially tricky issue for simulating _polymer_ jamming is that
again, it should be possible to set this up via fix adapt. the logic
of keeping changes in sync would have to be implemented the variable
expressions.
If a couple hooks are added to fix adapt, it should
also be possible to vary a bond potential’s parameters
over time, e.g. the equilibrium bond length. In that
case the bond length could grow as the particle
diameter increased. Don’t know what the analog
is for varying an angle.
