When using the read_restart command in a script with a wildcard, it seems like LAMMPS messes up if the filename is greater than 29 characters. Take the following files in a folder:
Restart file is correctly read and resumed from 012345678901234567890123456_B-100.restart
I didn’t see any documentation about filenames needing to be shorter than 29 characters, so to me this looks like a bug. My filenames are usually long as I have a lot of variables in my filenames.
units lj
atom_style atomic
lattice fcc 0.8442
region box block 0 2 0 2 0 2
create_box 1 box
create_atoms 1 box
mass 1 1.0
velocity all create 3.0 87287 loop geom
pair_style lj/cut 2.5
pair_coeff 1 1 1.0 1.0 2.5
neighbor 0.3 bin
neigh_modify every 1 delay 5 check no
fix 1 all nve
restart 100 01234567890123456789012345678901234567890_A-*.restart
thermo 50
run 500 post no
clear
shell rm 01234567890123456789012345678901234567890_A-500.restart
shell ls 01234567890123456789012345678901234567890_A-*.restart
read_restart 01234567890123456789012345678901234567890_A-*.restart
run 0 post no
It should generate 5 restart files on steps 100, 200, 300, 400, 500, then wipe out LAMMPS, delete the restart for step 500, read with wildcard and then pick up the step 400 restart as expected.
Setting up Verlet run ...
Unit style : lj
Current step : 0
Time step : 0.005
Per MPI rank memory allocation (min/avg/max) = 2.581 | 2.581 | 2.581 Mbytes
Step Temp E_pair E_mol TotEng Press
0 3 -6.7733681 0 -2.4139931 -3.781861
50 1.6613601 -4.8315081 0 -2.4173443 5.3583974
100 1.8620796 -5.124342 0 -2.4185075 4.0555983
150 1.646154 -4.8145181 0 -2.4224505 5.6638944
200 1.4445937 -4.5194162 0 -2.420241 6.895903
250 1.378496 -4.4156077 0 -2.4124807 6.9913609
300 1.6899999 -4.8748573 0 -2.4190763 5.313943
350 1.6283077 -4.7849736 0 -2.4188389 5.7547692
400 1.643819 -4.8059329 0 -2.4172585 5.5594792
450 1.8192217 -5.0631528 0 -2.4195963 4.3212518
500 1.5074663 -4.6113638 0 -2.4208269 6.1858876
Loop time of 0.062669 on 1 procs for 500 steps with 32 atoms
Reading restart file ...
ERROR on proc 0: Cannot open restart file ./01234567890123456789012345678901234567890_A-500.restart: No such file or directory (../read_restart.cpp:112)
If I comment out the mv shell command, there is no more error:
Loop time of 0.0673708 on 1 procs for 500 steps with 32 atoms
restart file = 29 Sep 2021, LAMMPS = 29 Sep 2021
restoring atom style atomic from restart
orthogonal box = (0.0000000 0.0000000 0.0000000) to (3.3591924 3.3591924 3.3591924)
restoring pair style lj/cut from restart
32 atoms
read_restart CPU = 0.003 seconds
WARNING: No fixes defined, atoms won't move (../verlet.cpp:55)
Neighbor list info ...
update every 1 steps, delay 10 steps, check yes
Here is information about my Linux release I’m using:
lsb_release -a
LSB Version: :core-4.1-amd64:core-4.1-ia32:core-4.1-noarch:cxx-4.1-amd64:cxx-4.1-ia32:cxx-4.1-noarch:desktop-4.1-amd64:desktop-4.1-ia32:desktop-4.1-noarch:languages-4.1-amd64:languages-4.1-noarch:printing-4.1-amd64:printing-4.1-noarch
Distributor ID: RedHatEnterpriseServer
Description: Red Hat Enterprise Linux Server release 7.9 (Maipo)
Release: 7.9
Codename: Maipo
It looks like the filesystem of the folder I’m running the script in is nfs.
If possible, kindly see if my shell command gives you the same error.
I have no problem with using the “shell mv” command. It picks up the step 400 file as expected.
The NFS file system is likely the problem. It probably does what is called “attribute caching” which can lead to the directory listing becoming inconsistent with the files.
Okay I see, thank you very much for testing it out on your own machine. I wasn’t aware of a possible caching issue, as I thought it would be all right as long as the filenames were under the ~255 character limit. I will bring this up with my system administrator.
Please go to your LAMMPS source and edit the file utils.cpp as follows, recompile, and try again.
diff --git a/src/utils.cpp b/src/utils.cpp
index eb9e48985a..aaca268174 100644
--- a/src/utils.cpp
+++ b/src/utils.cpp
@@ -1516,8 +1516,8 @@ static int re_matchp(const char *text, re_t pattern, int *matchlen);
/* Definitions: */
-#define MAX_REGEXP_OBJECTS 30 /* Max number of regex symbols in expression. */
-#define MAX_CHAR_CLASS_LEN 40 /* Max length of character-class buffer in. */
+#define MAX_REGEXP_OBJECTS 256 /* Max number of regex symbols in expression. */
+#define MAX_CHAR_CLASS_LEN 256 /* Max length of character-class buffer in. */
enum {
RX_UNUSED,
The problem is not the length of the filename, but how many characters are identical between files and how difficult it is to program a search to find the file with the largest number in place of the *.
With the old settings, strings that were the same in the first 30 characters were considered the same. So if a filename where character 31 was a B instead of an A but everything before was identical, it would still match the one with the A. This then would result in the wrong file name being read because the code would extract the number and then “synthesize” from the largest number found.
