Dear LAMMPS users,
I have ran a simulation for 10 ns, containing two organic molecules in 1000 water molecules. potential energy is contributed by
organic-organic, water-water, organic-water.
I want to separate them using rerun command. how can i do that… can anyone help in this regard.
organic molecules ( atomid 1 to 100) and water ( 101 to 3100)
spandana
Dear LAMMPS users,
I want to separate them using rerun command. how can i do that.. can anyone
look through the documentation about using compute group/group. it is
pretty straightforward.
Thanks Axel sir,
First I am learning to execute rerun command, and could me change in poteng from initial run at third or fourth decimal.
Is this fine or am I doing any wrong.
rerun dump.lammps every 1 dump x y z
spandana
Thanks Axel sir,
how should i know?
things don't get any more right or wrong because i say so. you have to
convince yourself. build a test system, make some hypothesis why this
difference could happen, check it out (by hand) and then you don't
need anybody else.
