Potassium meam potential from library.meam has errors I think
I believe that the parameters written in library.meam for K are wrong. The rest of this post explains my reasoning. I run the following code, which creates a box of K atoms in a bcc lattice, assigns the meam K potential to it, minimizes energy, sets starting velocities, and uses fix npt. I use the parameters for K in library.meam with no additional specified parameters.
units		metal
dimension 	3
boundary 	p p p
atom_style 	atomic
variable 	        latparam equal 5.344
variable 	        Tstart equal 300
variable 	        Patm equal 1.01325
timestep 	        0.001
lattice 	        bcc ${latparam}
region 		potato block 0 5 0 5 0 5
create_box 	1 potato
create_atoms 	1 region potato
pair_style 	meam
pair_coeff 	* * library.meam K NULL K
minimize 	       1.0e-5 1.0e-4 100 1000
velocity 	       all create ${Tstart} 83051 dist gaussian mom yes rot yes
compute 	        pe_id all pe pair
dump 		dumpid all atom 100 dumpfile
thermo_style    custom step temp press etotal vol pe
thermo 		50
fix 		        id1 all npt temp ${Tstart} ${Tstart} $(100*dt) iso ${Patm} ${Patm} $(100*dt)
run		       1000
The energy values printed are all zero during minimization. During the npt run, the box expands very quickly with atoms spreading out really far.
When I instead replace K with Na in the pair_coeff line and update the lattice parameter, the simulation works normally (bcc crystal structure maintained and energy nonzero during minimization). This proves that the format of the meam potential assignment is okay.
Furthermore, when I replace the potential with an available K eam/fs potential, I get a normal, working simulation. Therefore, it seems that the error lies in the K meam parameters printed in library.meam.
If I am missing something here and have an error in my reasoning or simulation code, please let me know. If not, hopefully this can help others in the future using simulations with potassium. Thank you!
Validity of force field parameters is not a LAMMPS issue (unless you can prove that LAMMPS does not read the parameter file correctly) and thus off-topic for this forum.
In most cases LAMMPS uses parameter files that were created for use with other programs. At any rate, you should review the publication(s) that describe the parameter set to determine, if it was parameterized for your use case and then contact both the author of that publication, if your case is covered, and the contributing author that submitted the parameter set to LAMMPS.
