Hi all,
I’m currently working on setting up atomate2, and part of this installation requires configuring VASP pseudopotentials with pymatgen. I’ve previously used these pseudopotentials with my own scripts and atomate, but with atomate2 I believe I’m having issues detecting the correct functional type.
I’ve been given unzipped POTCARs, matching this format
- <EXTRACTED_VASP_POTCAR>
|- potpaw_PBE
||- Ac_s
|||-POTCAR
I use pymatgen’s command line utility to generate the following structure
- <MY_PSP>
|- POT_GGA_PAW_PBE
||- POTCAR.Ac_s.gz
||- POTCAR.Ac.gz
||- POTCAR.Ag.gz
|- POT_GGA_PAW_PW91
This path is then added to my .pmgrc.yaml file. atomate runs fine, but following this example with atomate2 I receive the following error:
OSError: You do not have the right POTCAR with functional PBE_54 and label Si in your VASP_PSP_DIR
I’m unsure why atomate2 is looking for the PBE_54 functional, it’s not specified in my .pmgrc.yaml file. I don’t know if this an issue specifically with atomate2, or a general POTCAR setup issue. Any help is greatly appreciated.
Thanks for your time!
