Dear users,
Trying to verify the output from pair_write command for coul/long pair_style with the analytic form of coulomb potential.
The comparison is inside cutoff distance. Both the potential values should match but they are differing with each other.
If I understand correct, pair_write must write the exact form of potential given by pair_style.
Also, what should be value of C and epsilon if wish to find correct coulomb potential. We are considering (1/4piepsilon) included with
potential form.
Anyway, tested with all possible permutations/combinations. No success. Attached a simple input file.
Can one please point out the missing links!
Regards
in.test_pair_write (1.49 KB)
I suggest you try using pair write with a cutoff LJ
potential first, e.g. pair lj/cut and verify that you
are able to compare it to an analytic formula.
They try a Coulomb potential. If you are doing
this in non-LJ units, e.g. real or metal, then
you will have to understand the energy units
that LAMMPS uses in each case for LJ and
Coulombic in order to compare to your formula.
Dear Steve,
Sending you the comparison u asked for. 3 cases taken into account.
- LJ/cut with LJ units
- Yukawa with SI units
- Coul/long with SI units
all plots are from 0.2 cutoff to cutoff distance in respective normalization.
The attached plots shows perfect matching with its analytic form for Yukawa and LJ/cut case while for Coul/long,
the results not matching.
I wonder if the problem related with value of C and epsilon in coul/long potential. As no suggestions for
providing these values given in pair_coeff.
test_pot.pdf (14.2 KB)
Dear Steve,
1. LJ/cut with LJ units
2. Yukawa with SI units
3. Coul/long with SI units
normalization.
Am I missing something here? How does coul/long have C and epsilon?
Ray
Hi Ray Shan,
I clarify my statement.
I was just saying from pot. energy form in manual: its E = CQ1Q2/epsilonr
As there is no needed value of pair_coeff for coul/long case, is the value (C/eps) is equal to (1/4pi*epsilon_0)!
I just posed my doubt because i am unable to match analytic form of this potential to pair write value. While for other potentials, as i have shown, both are matching.
Hi Ray Shan,
It cannot match because your formula is for coul/cut not coul/long.
Hi Axel,
Got the missing link. Thanks for pointing out. Its perfectly matching with coul/cut and must not
match as written in manual … due to kspace_style.
All other confusions buried with this solutions.
Thanks again.
