PPPM IN 2D
Dear lammps users
Recently, I ran a simulation with pppm method, and fortunately I tool good results.
But now, I assign “kspace_modify slab 3.0” to omit long coulomb intraction affect from periodic boxes in z direction. So, I changed boundaries to “p p f”.
Unfortunately, I get the following error in different circumstances.
ERROR on proc 1: Shake atoms 17521 17522 17523 missing on proc 1 at step
66079 (…/fix_shake.cpp:521)
MPI_ABORT was invoked on rank 1 in communicator MPI_COMM_WORLD
with errorcode 1.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
I tested different cutoff radius and neighbour, but the error occured again.
I will appreciate if you could help me.
Regards
Reza
changedinput.in
complete.data
Dear lammps users
results.
But now, I assign "kspace_modify slab 3.0" to omit long coulomb intraction
affect from periodic boxes in z direction. So, I changed boundaries to "p p
f".
> 66079 (../fix_shake.cpp:521)
> with errorcode 1.
again.
​no big surprise here when looking at your system. if you run a simulation
of a droplet of a liquid in vacuum long enough, some molecule will
evaporate from the droplet and for a system with fixed boundaries, it will
eventually leave the box.​ have you visualized your trajectory? you should
see a molecule leaving the droplet before you receive the quoted error
message.
​you need to have some kind of mechanism to keep atoms from leaving the box
(in fact, for an accurate simulation​, atoms should stay within the
original box confines, i.e. before the expansion through the PPPM kspace
slab solver). you can define walls with a (soft) harmonic potential, for
example.
​axel.​
Dear Axel
Thank you so much for your response.
Unfortunately, I got the previous error when I added another Graphene sheet to confine the simulation box. I tested different options of fix wall/reflect to do so,but the error emerged again.
I don’t know why this error occured for one molecule on two processor.
Error:
Dear Axel
I don't know why this error occured for one molecule on two processor.
Error:
ERROR on proc 7: Shake atoms 17413 17414 17415 missing on proc 7 at step
373180 (../fix_shake.cpp:530)
ERROR on proc 3: Shake atoms 17413 17414 17415 missing on proc 3 at step
MPI_ABORT was invoked on rank 7 in communicator MPI_COMM_WORLD
with errorcode 1.
I will appreciate if you could tell me the reason of this error.
LAMMPS Molecular Dynamics Simulator
