Dear Users,
I am modeling pressure driven flow in a nano-channel. For calculating the pressure gradient along the channel I have to use stress/atom command in bins. As a first step, I ran the sample command given in the documentation.
Command used to calculate pressure,
compute peratom all stress/atom NULL
compute p all reduce sum c_peratom[1] c_peratom[2] c_peratom[3]
variable press equal -(c_p[1]+c_p[2]+c_p[3])/(3*vol)
thermo_style custom step temp c_tu c_tl c_tf press v_press
The last two terms in thermo output are not matching. (the difference in the value is persisting and the first term is larger than the second)
NOTE:
Pair modify command is not used in the script.
Thanking in advance for your kind help.
ABDUL GAFOOR C P
Dear Users,
the documentation.
thermo_style custom step temp c_tu c_tl c_tf *press* *v_press*
Does your simulation box contains a lot of vacuum? I assume that the
equivalence between press and v_press is valid only in the case of
"continuous" system. No?
Julien.
Sir,
I am modeling an Argon gas flow in nano-channel with a Knudsen Number 0.066.
Is there any other way to monitor the pressure in thermo output when our system is not continuous?
Regards
ABDUL GAFOOR
