hello everyone,
i’m having some problem to calculate the pressure of a group of liquid-vapor. The calculated pressure seems to be high than what it should be. I’m using the following to calculate the pressure. Here i am calculating the diagonal components.
compute S L_V stress/atom mytemp
compute pLV L_V reduce sum c_S[1] c_S[2] c_S[3]
variable Pres equal -(c_pLV[1]+c_pLV[2]+c_pLV[3])/(3* volume of the region)
Thanks in advance for any help.
Best regards, Som Subhra.
hello everyone,
i'm having some problem to calculate the pressure of a group of
be. I'm using the following to calculate the pressure. Here i am calculating
help with what? and on what grounds? there is nothing here.
