I am working with the Rutile TiO2 structure, specifically a 4 x 4 x 2 bulk supercell, with periodic boundary conditions enforced in all three directions. My goal is to optimise the lattice parameters of this supercell at absolute zero temperature. Essentially, I want to relax the structure anisotropically to zero pressure (given Rutile’s tetragonal symmetry). I trained a DeepMD potential beforehand which I use to compute pairwise interactions.
I wrote a script reading in the data file with an initial set of atomic coordinates that I created from a CIF file obtained using the Materials Project Database. I then used fix box/relax with aniso 0.0 and vmax initially set to 1e-3, (I made vmax smaller (going to 1e-5) in a restarted run as well) then ran a minimisation of the simulation box followed by simultaneous refinement of atomic positions.
During the initial run, the pressure decreased monotonically for a large part of its run, then inexplicably flattened out and decreased at a much slower rate. When it terminated, the stopping criterion was “Energy Tolerance”, which makes me think that the algorithm swiftly converged to a local energy minimum and was unable to get out of it. In later runs, I would also get a “linesearch alpha is zero” stopping criterion.
Interestingly, I also tried this with a 5 x 5 x 5 supercell. There, I used the same approach with isotropic relaxation and it converged to zero pressure within a few hundred steps, although its local symmetry was significantly altered. Even isotropic relaxation, when applied to the 4 x 4 x 2 supercell, faces energy tolerance criterion stoppage issues at large non-zero pressures.
I also tried the approach taken by one of the official tutorials here. This approach, when applied to the 4 x 4 x 2 system, also stopped prematurely citing the same energy tolerance criterion, and I cannot figure out why this is happening.
I have included my input file, data file and log file from the initial run of the 4 x 4x 2 system (wherein I tried anisotropically relaxing the structure). I would appreciate any insights into why the pressure and forces are failing to converge. I am also happy to share additional scripts from other runs if need be.
Input Script:
atom_style atomic
read_data rutile_442.lmp
pair_style deepmd frozen_model.pb
pair_coeff * *
neighbor 2.0 bin
thermo 1
thermo_style custom step pe press lx ly lz
write_restart restart.file
## 1. USER PARAMETERS FOR CONVERGENCE
## Target and tolerance (bar)
variable Ptarget equal 0.0
# (A) Anisotropic box relaxation
min_style cg
fix aniso all box/relax aniso ${Ptarget} vmax 1e-3
minimize 1e-8 1e-8 10000 100000
# (B) Final atomic positions refinement
Data (containing atomic coordinates):
# Ti2 O4
192 atoms
2 atom types
0.000000000000 18.399349280000 xlo xhi
0.000000000000 18.399349280000 ylo yhi
0.000000000000 5.918427120000 zlo zhi
Masses
1 47.86700000 # Ti
2 15.99900000 # O
Atoms # atomic
1 1 2.299918660000 2.299918660000 0.000000000000
2 1 0.000000000000 0.000000000000 1.479606780000
3 2 3.200008800991 3.200008800991 1.479606780000
4 2 0.900090140991 3.699747179009 0.000000000000
5 2 3.699747179009 0.900090140991 0.000000000000
(187 more rows)
Log file:
CITE-CITE-CITE-CITE-CITE-CITE-CITE-CITE-CITE-CITE-CITE-CITE-CITE
Generated 0 of 1 mixed pair_coeff terms from geometric mixing rule
Neighbor list info ...
update: every = 1 steps, delay = 0 steps, check = yes
master list distance cutoff = 9
ghost atom cutoff = 9
binsize = 4.5, bins = 5 5 2
1 neighbor lists, perpetual/occasional/extra = 1 0 0
(1) pair deepmd, perpetual
attributes: full, newton on
pair build: full/bin/atomonly
stencil: full/bin/3d
bin: standard
WARNING: Energy due to 3 extra global DOFs will be included in minimizer energies
(src/min.cpp:219)
Per MPI rank memory allocation (min/avg/max) = 4.301 | 4.301 | 4.301 Mbytes
Step PotEng Press Lx Ly Lz
0 -1515.9694 428834.72 18.399349 18.399349 5.9184271
1 -1517.3283 405322.28 18.417728 18.417749 5.9226245
2 -1518.6655 381601.34 18.435451 18.436148 5.9266257
3 -1519.9085 355670.67 18.453065 18.454547 5.9304581
4 -1521.0843 327694.44 18.470556 18.472947 5.9341003
5 -1522.1255 297607.04 18.487888 18.491346 5.9375196
6 -1523.0799 266619.99 18.505043 18.509745 5.9406847
7 -1523.8857 233321.48 18.521978 18.528145 5.9435459
8 -1524.5943 199807.89 18.538648 18.546544 5.9460411
9 -1525.2012 166346.18 18.554983 18.564943 5.9480827
10 -1525.7015 133455.7 18.570891 18.583343 5.9495536
11 -1526.1057 102181.25 18.586252 18.601742 5.9502957
12 -1526.4397 73456.605 18.600908 18.620141 5.9501022
13 -1526.7146 48425.305 18.614654 18.638541 5.9487085
14 -1526.9572 28360.847 18.627265 18.65694 5.9458194
15 -1527.1998 14276.187 18.638567 18.67534 5.9412092
16 -1527.4445 6596.3123 18.648 18.692658 5.9352908
17 -1527.6741 3525.0142 18.655239 18.70726 5.9293723
18 -1527.8903 1968.9798 18.661674 18.72088 5.9234539
19 -1528.1018 1170.3746 18.667711 18.734014 5.9175355
20 -1528.3106 726.97072 18.673541 18.746896 5.9116171
21 -1528.5176 463.72301 18.679252 18.759631 5.9056986
22 -1528.7232 293.15733 18.68489 18.772272 5.8997802
23 -1528.8341 97.661251 18.689945 18.783648 5.8944251
24 -1528.9794 -808.00065 18.708345 18.782988 5.8886721
25 -1529.0513 -1183.7272 18.725033 18.768131 5.8879541
26 -1530.8136 11939.991 18.743433 18.764985 5.8826662
27 -1531.1576 12352.859 18.758846 18.769248 5.8767478
28 -1531.3968 10544.744 18.769871 18.780264 5.8708294
29 -1531.4358 8087.7585 18.788105 18.777379 5.8670713
30 -1531.4389 -913.62874 18.79156 18.779916 5.8683218
31 -1531.4401 -875.05495 18.790627 18.779133 5.8688243
32 -1531.4414 534.77054 18.789038 18.777862 5.8692071
33 -1531.4425 -195.5915 18.788468 18.777536 5.869724
34 -1531.443 -105.45002 18.78797 18.777174 5.869952
35 -1531.4436 -87.294242 18.787515 18.776851 5.8701796
36 -1531.4441 -82.513789 18.787068 18.776535 5.8704075
37 -1531.4443 -81.685032 18.786867 18.776393 5.8705105
38 -1531.4443 -81.645941 18.786856 18.776385 5.8705163
Loop time of 5.61363 on 1 procs for 38 steps with 192 atoms
1485.6% CPU use with 1 MPI tasks x 1 OpenMP threads
Minimization stats:
Stopping criterion = energy tolerance
Energy initial, next-to-last, final =
-1515.96938637628 -1531.44433389589 -1531.44434754222
Force two-norm initial, final = 939.4985 6.5838898
Force max component initial, final = 594.09391 3.1017355
Final line search alpha, max atom move = 3.1475601e-07 9.7628989e-07
Iterations, force evaluations = 38 72
MPI task timing breakdown:
Section | min time | avg time | max time |%varavg| %total
Pair | 5.6035 | 5.6035 | 5.6035 | 0.0 | 99.82
Neigh | 0.0014525 | 0.0014525 | 0.0014525 | 0.0 | 0.03
Comm | 0.0017821 | 0.0017821 | 0.0017821 | 0.0 | 0.03
Output | 0.0012273 | 0.0012273 | 0.0012273 | 0.0 | 0.02
Modify | 0 | 0 | 0 | 0.0 | 0.00
Other | | 0.005695 | | | 0.10
Nlocal: 192 ave 192 max 192 min
Histogram: 1 0 0 0 0 0 0 0 0 0
Nghost: 2952 ave 2952 max 2952 min
Neighs: 0 ave 0 max 0 min
FullNghs: 53632 ave 53632 max 53632 min
Total # of neighbors = 53632
Ave neighs/atom = 279.33333
Neighbor list builds = 1
Dangerous builds = 0
(src/min.cpp:219)
39 -1531.4444 -81.124708 18.78685 18.776381 5.8705192
Loop time of 1.4188 on 1 procs for 1 steps with 192 atoms
1539.1% CPU use with 1 MPI tasks x 1 OpenMP threads
Minimization stats:
-1531.44434754222 -1531.44434754222 -1531.44435443502
Force two-norm initial, final = 6.5903261 6.5899132
Force max component initial, final = 3.0766263 3.0768585
Final line search alpha, max atom move = 1.5870671e-07 4.883181e-07
Iterations, force evaluations = 1 18
Pair | 1.4156 | 1.4156 | 1.4156 | 0.0 | 99.77
Neigh | 0.0013218 | 0.0013218 | 0.0013218 | 0.0 | 0.09
Comm | 0.00046373 | 0.00046373 | 0.00046373 | 0.0 | 0.03
Output | 0 | 0 | 0 | 0.0 | 0.00
Other | | 0.001433 | | | 0.10
Total wall time: 0:00:08
