Liquid density in your configuration is not really something you can “set”… It is instead a property reflecting the quality of the force field (potential) used.
Ray
Ray
Thanks, Shan
But I want to set the fluid pressure at a given value. However, solid also take part in the pressure calculation.
Given solid is immobile, how could I only set liquid pressure?
That is not something you can set in your simulation setup.
Ray
I know there is not a straightforward option.
So, there is any trick for this purpose?
