I am simulating gas hydrate crystals in LAMMPS using fix npt
. When I specify lower pressure of 20 atm, the average pressure of the system is initially at the range of 20 atm but later during the simulation it socialites a lot (it even becomes negative sometimes). I even used drag 2.0 but it did not solve my problem. Anybody has any idea how I can damp those oscillations effectively? Note that I do not face this problem for higher pressure of 100 atm.
Below is my input file:
#----- conversion factors and coefficients
variable ps2fs equal 1e3
variable ns2fs equal 1e6
variable ms2fs equal 1e9
variable fs2s equal 1e-15
variable atm2Pa equal 101325.0
variable A2m equal 1.0e-10
variable rnd equal round(random(0,999,${RANDOM})) # random number for velocity initialization
# Number of unit cell replicas
variable Nx equal 20
variable Ny equal 10
variable Nz equal 10
# time-step
variable dt equal 10.0
#----- Set time duration for each ensemble integration
variable tNVT equal 500 # in ps
variable N_NVT equal floor(${tNVT}*${ps2fs}/${dt})
variable tNPT equal 0.001 # in ms
variable N_NPT equal floor(${tNPT}*${ms2fs}/${dt})
variable tNVT_fixedHydrate equal 0.100
variable N_NVT_fixedHydrate equal floor(${tNVT_fixedHydrate}*${ms2fs}/${dt})
#----- set thermodynamic properties
variable Thyd equal 250
variable Phyd equal 493
variable Tdiss equal 450
variable Tdamp equal $(100*v_dt)
variable Pdamp equal $(1000*v_dt)
#----- path to the forcefield folder, unit-cell folder, and the directory to the property calculation files
variable uc_folder string "/scratch/madibi/MDSim/co2Hydrate/cg_model/unit_cell/"
variable ff_folder string "/filtered_ff_candidates"
variable props_in_folder string "../../../propsCalc/" # not using it currently
# file names for uc
variable uc_fileName string s1_unit_cell_mw_co2.data
#-------------------------- Set global settings of the simulations --------------------
# time-step
timestep ${dt}
# set neighboring parameter (skin)
neighbor 2.0 bin
neigh_modify one 5000
#---------------------------------- Init Section ----------------------------------
units real
atom_style full
pair_style sw
#---------------------------------- Initial Configuration ----------------------------------
# Create the simulation box or load from previous restart run.
read_data ${uc_folder}${uc_fileName}
replicate ${Nx} ${Ny} ${Nz}
# Initialize the velocity if needed
velocity all create ${Thyd} ${rnd} mom yes rot yes dist gaussian loop geom
# Conserve the linear and angular momentums
fix removeMomentum all momentum 1 linear 1 1 1 angular
#---------------------------------- Forcefield parameters Section ----------------------------------
# load forcefield parameters
pair_coeff * * water_co2_base.sw O C
# write-out the initial configuration of the molecules
write_data initial_config.data
#---------------------------------- Energy Minimization (only if num_rest_curr==0) ----------------------------------
thermo 1
thermo_style custom fmax fnorm
minimize 1.0e-5 1.0e-10 1000000 4000000
reset_timestep 0
write_data AfterMinimization.data
#-------------------------- s,p,d for time-averaged calculations --------------------------
variable s equal 10 # sample interval
variable p equal 100 # correlation length
variable d equal $s*$p # dump interval to calculate thermodynamic properties
variable time equal time
variable Vout equal vol
variable Pout equal press
variable Tout equal temp
variable Hout equal enthalpy
variable PEout equal pe
variable KEout equal ke
variable ETOTout equal etotal
variable massDensity equal density
# global scalar properties
fix GlobalPropsTimeAvg all ave/time $s $p $d v_Pout v_Tout v_Vout v_Hout v_PEout v_KEout v_ETOTout v_massDensity file GlobalPropsTimeAvg.prop
# vector properties
compute myRDF all rdf 50 1 1 2 2 1 2
fix rdfOut all ave/time $s $p $d c_myRDF[*] file rdf_all.rdf mode vector
#-------------------------- Simulations --------------------------
# Setup thermo output.
thermo_style custom step pe vol press temp
thermo 500
##### NVT relaxation
print "****************************************"
print "NVT relaxation at Thyd=${Thyd}"
dump trjNVT all custom 20000 NVT_Trajectory.lammpstrj id mol type x y z ix iy iz vx vy vz
dump_modify trjNVT header yes time yes flush yes
fix NVTequil all nvt temp ${Thyd} ${Thyd} ${Tdamp} drag 0
run ${N_NVT}
unfix NVTequil
undump trjNVT
write_restart restart.AfterNVT
write_data data.AfterNVT
##### NPT for pressure equilibration
print "NPT hydrate at Thyd=${Thyd} and Phyd=${Phyd}"
dump trjNPT all custom 20000 NPT_Trajectory.lammpstrj id mol type x y z ix iy iz vx vy vz
dump_modify trjNPT header yes time yes flush yes
fix NPTSim all npt temp ${Thyd} ${Thyd} ${Tdamp} iso ${Phyd} ${Phyd} ${Pdamp} drag 0
run ${N_NPT}
unfix NPTSim
undump trjNPT
write_restart restart.AfterNPT
write_data data.AfterNPT
##### Increase temperature in the water_methane zone (NVT)
print "NVT equilibration to partially melt hydrate at T=${Tdiss}"
dump trjNVT_eql all custom 20000 NVT_eql_Trajectory.lammpstrj id mol type x y z ix iy iz vx vy vz
dump_modify trjNVT_eql header yes time yes flush yes
# Set different zones in the simulation box
variable DX equal (xhi-xlo)/2
variable Xi_hyd equal xlo+0.25*(xhi-xlo)
variable Xf_hyd equal ${Xi_hyd}+${DX}
region hydrate_reg block ${Xi_hyd} ${Xf_hyd} INF INF INF INF
region water_methane_left block INF ${Xi_hyd} INF INF INF INF
region water_methane_right block ${Xf_hyd} INF INF INF INF INF
region water_methane_reg union 2 water_methane_left water_methane_right
group HydrateAtoms region hydrate_reg
group WaterMethaneAtoms region water_methane_reg
fix NVT_fixedHydrate WaterMethaneAtoms nvt temp ${Tdiss} ${Tdiss} ${Tdamp} drag 0.0
run ${N_NVT_fixedHydrate}
unfix NVT_fixedHydrate
undump trjNVT_eql
write_restart restart.AfterNVTFixedHydrate_${Nx}_${Ny}_${Nz}
write_data data.AfterNVTFixedHydrate_${Nx}_${Ny}_${Nz}
