primitive cell of bcc
I have a problem understanding the primitive cell of the bcc structure. As we can see from the example diretory of atat that the bcc_lat.in of bcc is in the following format:
1 1 1 90 90 90
0.5 0.5 0.5
0.5 -0.5 0.5
0.5 0.5 -0.5
0 0 0 A
and the corresponding lattice parameters, a,b,c,alpha,beta,gamma
is 0.86603 0.86603 0.86603 109.47122 70.52878 70.52878
but i also found that the primitive cell of the bcc would be:
1 1 1 90 90 90
-0.5 0.5 0.5
0.5 -0.5 0.5
0.5 0.5 -0.5
0 0 0 A
and the corresponding lattice parameters, a,b,c,alpha,beta,gamma:
0.86603 0.86603 0.86603 109.47122 109.47122 109.47122
I donot know whether they may result in different sqs structures.
Regards,
wzchen
Both unit cells are valid.
The same (up to symmetry transformations) SQSes would be generated.
Of course, if you use mcsqs (which I suggest), the output is determined by some random numbers too, so different runs may give different outputs, but not because of unit cell differences.
Thanks :smiley:
