I wish to simply compute the potential energy of the current configuration of the atoms using some interatomic potential and then simply print/output it. However, when i tried with the following input script:
#----------------------- INITIATION-----------------------------------------------
kim init Tersoff_LAMMPS_Tersoff_1988_C__MO_579868029681_003 metal
#units metal
boundary f f f #X-periodic Y-periodic Z-periodic
atom_style full
newton on
#---------------------- ATOM DATA-------------------------------------------------
read_data mytube_200-2.txt
#---------------------- FORCE FIELD-----------------------------------------------
#pair_style airebo 3.0 1 1
#pair_coeff * * CH.airebo C
#pair_style tersoff
#pair_coeff * * 1989_SiC.tersoff C
kim_interactions C
neighbor 1.0 bin
#---------------------- GROUP DEFINITION------------------------------------------
region lower block INF INF INF INF INF 5 units box
region upper block INF INF INF INF 220 INF units box
group upper region upper
group lower region lower
group boundary union upper lower
group mobile subtract all upper lower
fix 1 all nve
dump 1 all atom 100 dump.min
thermo 1
thermo_style custom step temp pe etotal fnorm fmax
compute 1 all pe
variable pe equal pe
print ${pe} append energy.txt screen no
However, i get the following error:
LAMMPS (23 Jun 2022 - Update 1)
OMP_NUM_THREADS environment is not set. Defaulting to 1 thread. (src/comm.cpp:98)
Reading data file ...
orthogonal box = (-50 -50 -300.61401) to (50 50 744.99079)
reading atoms ...
3899 atoms
special bond factors lj: 0 0 0
special bond factors coul: 0 0 0
0 = max # of 1-2 neighbors
0 = max # of 1-3 neighbors
0 = max # of 1-4 neighbors
1 = max # of special neighbors
special bonds CPU = 0.001 seconds
read_data CPU = 0.013 seconds
WARNING: 'kim_<command>' has been renamed to 'kim <command>'. Please update your input.
399 atoms in group upper
80 atoms in group lower
479 atoms in group boundary
3420 atoms in group mobile
ERROR: Energy was not tallied on needed timestep (src/thermo.cpp:1132)
Last command: print ${pe} append energy.txt screen no
Why am i getting this error and how to fix it?
