Dear colleagues,
I had the impression that the order in which a model specifies the supported NBC methods indicates a kind of priority for that model (perhaps a model has better performance with one kind of neighbor lists than with another). But I see nowhere in the KIM API any method to read the list of PBC methods and get this order. In fact, the test vc_force_delta.F90 appears to identify the possible neighbor list methods in quite a clumsy way, by testing for them one by one (see below). Should there not be some kind of API method for getting a (preferably prioritised) list of supported neighbor list methods? Something similar to KIM_API_get_model_partcl_typs().
Best regards
Jakob
subroutine Get_Model_NBC_methods(modelname, max_NBCs, model_NBCs, num_NBCs, ier)
use KIM_API
implicit none
!-- Transferred variables
character(len=100), intent(in) :: modelname
integer, intent(in) :: max_NBCs
character(len=KIM_KEY_STRING_LENGTH), intent(out) :: model_NBCs(max_NBCs)
integer, intent(out) :: num_NBCs
integer, intent(out) :: ier
!-- Local variables
integer :: index
!-- KIM variables
integer(kind=kim_intptr) pkim
! Initialize error flag
ier = KIM_STATUS_OK
! Generate empty KIM object containing generic model info
ier = kim_api_model_info_f(pkim, modelname)
if (ier.lt.KIM_STATUS_OK) return
! Identify supported NBCs by seeking index to each of the NBCs in the KIM model
num_NBCs = 0
! NEIGH_RVEC_H
index = kim_api_get_index_f(pkim, "NEIGH_RVEC_H", ier)
if (index.ge.0) then
num_NBCs = num_NBCs + 1
if (num_NBCs>max_NBCs) then
ier = KIM_STATUS_FAIL
return
endif
model_NBCs(num_NBCs) = "NEIGH_RVEC_H"
endif
! NEIGH_PURE_H
index = kim_api_get_index_f(pkim, "NEIGH_PURE_H", ier)
return
endif
model_NBCs(num_NBCs) = "NEIGH_PURE_H"
endif
! NEIGH_RVEC_F
index = kim_api_get_index_f(pkim, "NEIGH_RVEC_F", ier)
return
endif
model_NBCs(num_NBCs) = "NEIGH_RVEC_F"
endif
! NEIGH_PURE_F
index = kim_api_get_index_f(pkim, "NEIGH_PURE_F", ier)
return
endif
model_NBCs(num_NBCs) = "NEIGH_PURE_F"
endif
! MI_OPBC_H
index = kim_api_get_index_f(pkim, "MI_OPBC_H", ier)
return
endif
model_NBCs(num_NBCs) = "MI_OPBC_H"
endif
! MI_OPBC_F
index = kim_api_get_index_f(pkim, "MI_OPBC_F", ier)
return
endif
model_NBCs(num_NBCs) = "MI_OPBC_F"
endif
! CLUSTER
index = kim_api_get_index_f(pkim, "CLUSTER", ier)
return
endif
model_NBCs(num_NBCs) = "CLUSTER"
endif
! free temporary storage
call kim_api_free_f(pkim,ier)
return
end subroutine Get_Model_NBC_methods
