Dear Julian, Hi.
As in the molecular editor tool, “Avogadro”, which one can choose force fields from: GAFF, Ghemical, MMFF94, MMFF94s, UFF; to minimize the energies, is it possible in gulp to use such a library instead of using the parameters in the input files?
If yes, where can I find an input template?
Thanks in advance.
Mahmoud
Hi Mahmoud
Rather than answer directly, I thought it would be better to coach you in how you can find answers yourself as this is a valuable skill to have for a researcher:
- Read the manual or look in the help text that comes with GULP or is available on line.
- Look at the example files that come with the code
- Look around the files that come with GULP (or search using “find” or equivalent)
- Type GULP and UFF (for example) into a search engine
If you have no luck with any of these then I’ll explain further.
Julian
Hi Julian.
Thank you so much for your reply.
More or less I usually use my learned skills to find answers to questions by myself, but sometimes time matters and one tries to find a shortcut
I had found example49 which had used the uff library and also had quick look at the UG, but did not succeed to find the simple answer. I just needed, in the first step of uff usage, a simple input template for a mono-atomic structure, and then refer to example49.
Mahmoud
Hi Mahmoud,
If you want to save time then you just buy a copy of Materials Studio and then it will write the inputs for you. Not sure there is much to add to example49 - you just need to atom type your structure and off you go…
Regards,
Julian
Dear Julian,
Hi.
Thank you so much for your tips and helps; suffices to try.
I highly appreciate your kind helps even though “time” matters very much for you handling lots of things, and I am so sorry if I took your time.
Best wishes,
Mahmoud
