I want to use EDIP potential to do some simulations about bulk si. It
is very simple model. But the calculated energy using EDIP
potential in LAMMPS is positive. My input file is as follows:
atom_style atomic
neighbor 2.0 bin
neigh_modify every 10
read_data data.txt
newton on
mass 1 28.086
pair_style edip
pair_coeff * * Si.edip Si
timestep 0.0001
thermo_style custom step temp etotal vol press pxx pyy pzz lx ly lz xhi yhi zhi
thermo 1000
velocity all create 300 5812775 dist uniform
dump 1 all xyz 1000 dump1.xyz
fix 1 all npt temp 300 300 0.01 x 0 0 0.01 y 0 0 0.01 z 0 0 0.01
couple none drag 0.2
run 10000
results are as follows:
LAMMPS (21 Sep 2012)
Reading data file ...
orthogonal box = (0 0 0) to (38.4023 37.6264 39.9088)
2 by 2 by 2 MPI processor grid
2880 atoms
Setting up run ...
Memory usage per processor = 1.62935 Mbytes
Step Temp TotEng Volume Press Pxx Pyy Pzz Lx Ly Lz Xhi Yhi Zhi
0 300 -13280.224 57665.741 2291.0518
2268.6894 2301.3285 2303.1375 38.40226 37.626379
39.9088 38.40226 37.626379 39.9088
1000 230.66921 85.841229 4.5776652e+13 2.0029541e-06
2.002954e-06 2.0029542e-06 2.0029541e-06 35340.545 34992.192
37016.865 17689.474 17514.909 18528.387
So, is there anything wrong with this input file? or if there is
something wrong with the newest EDIP codes?
Thank you very much in advance.
I think you just have a too small pdamp value. On 1000th step, the
volume and pressure blew up, so that it is meaningless to look at the
temperature when dynamics is wrong.
Please see the doc page on how to choose tdamp and pdamp values.
Thank you for your reply.
I just ran the same simulation of the same model (bulk silicon) using
the old version of EDIP in Lammps(lammps-21Mar12). The result is good.
So, I think there should be some problems with the newest version of
EDIP in Lammps(lammps-21Sep12).
The result is as follows:
LAMMPS (21 Mar 2012)
atom_style atomic
read_data data.txt
2880 atoms
newton on
mass 1 28.086
pair_style edip
