I’m trying to use compute heat/flux command to calculate thermal conductivity of Cu-Ar nanofluids while facing an error which goes :
ERROR: Invalid thermo keyword in variable formula (…/variable.cpp:2008)
I’ve checked my program and found no error. Besides, i notice that while the fix ave/correlate command was annotated, the error disappeared.(although the error messege says error relates to the variable formula) I’m confused about this problem and i appreciate any advice.
Part of my program is as follows: (I’m using LAMMPS (8 Jun 2016-ICMS))
thermpal conductivity calculation
compute ArKe Ar ke/atom
per-atom vector
compute ArPe Ar pe/atom
per-atom vector
compute ArS Ar stress/atom NULL virial
per-atom vector
compute ArFlux Ar heat/flux ArKe ArPe ArS
6 component vector:[Jx Jy Jz Jx_v Jy_v Jz_v]
compute ArVelo Ar property/atom vx vy vz
3 per-atom vectors
variable ArEnthalpy equal ave(c_ArKe)+ave(c_ArPe)
scalar
variable ArfluxX equal c_ArFlux[1]-(v_ArEnthalpy*sum(c_ArVelo[1]))
scalar, partial enthalpy of each atom
variable ArfluxY equal c_ArFlux[2]-(v_ArEnthalpysum(c_ArVelo[2]))
variable ArfluxZ equal c_ArFlux[3]-(v_ArEnthalpysum(c_ArVelo[3]))
compute CuKe Cu ke/atom
compute CuPe Cu pe/atom
compute CuS Cu stress/atom NULL virial
compute CuFlux Cu heat/flux CuKe CuPe CuS
compute CuVelo Cu property/atom vx vy vz
variable CuEnthalpy equal ave(c_CuKe)+ave(c_CuPe)
variable CufluxX equal c_CuFlux[1]-(v_CuEnthalpysum(c_CuVelo[1]))
variable CufluxY equal c_CuFlux[2]-(v_CuEnthalpysum(c_CuVelo[2]))
variable CufluxZ equal c_CuFlux[3]-(v_CuEnthalpy*sum(c_CuVelo[3]))
variable fluxX equal ArfluxX+CufluxX
scalar
variable fluxY equal ArfluxY+CufluxY
variable fluxZ equal ArfluxZ+CufluxZ
fix JJ all ave/correlate $s $p $d &
v_fluxX v_fluxY v_fluxZ type auto &
file profile.heatflux ave running
error occurs here
#variable scale equal s*dt*{convert}/vol/${kB}/$t/t
#variable k11 equal trap(f_JJ[3])*{scale}
#variable k22 equal trap(f_JJ[4])*{scale}
#variable k33 equal trap(f_JJ[5])*{scale}
#variable kappa equal (v_k11+v_k22+v_k33)/3.0
thermo $d
thermo_style custom step temp density
v_fluxX v_fluxY v_fluxZ v_k11 v_k22 v_k33 v_kappa
dump 4 all xyz 5000 calculation.xyz
run ${step_2}
George
