Something confused me about the “velocity” command. I used the command “velocity all create 300.0 492845 rot yes dist gaussian” to distribute velocity to all the molecular. According to my understanding , the velocity should be distributed randomly obeying gaussian distribution. Namely if i do the same simulation twice, the result should be different because the velocity of molecular should be different. But according to my result, i find that if the calculation is made in the same computer using the same cores, the result is the same. So that confused me a lot, how can the “velocity” command distribute the velocity? and can it remain unchanged in the same input?
Yours sincerely
David bootman.
command "velocity all create 300.0 492845 rot yes dist gaussian" to
this is where you go wrong. if you use the *exact* same input and the same
number of CPU cores, the result should be the same. to get a different set
of (pseudo!) random numbers, you have to use a different seed value.
