Dear LAMMPS-Users,
Actually, I have asked this question 2-3 days ago. Dear Axel gave me some clues on that time but my problem was not resolved. I really attempted to solve my problem myself however I could not found more things about that through searching the mailing list. So, please accept my apologies for posting this question again.
I am trying to simulate a box with two carbon atom walls filled by SPC/E water. I would like to immobilize the carbon atom walls via applying the “fix setforce” along side “ fix move” commands. I also preferred to use “fix nvt” just on water molecules aimed at time integrating.
By applying different values for “timestep” I will come across to some quite different outputs for Temp PotEng TotEng and Press.
I would be greatly appreciated by sharing your comments that what things may lead to happen these issues?
Thanks in advance
MajiD
Please take a look at the outputs as follows
Ts=0.02
Step Temp PotEng TotEng Press Volume
100 260.85822 -12940.01 -10258.175 4774.8327 36000
200 264.42727 -12143.879 -9425.3517 3379.0445 36000
300 261.51265 -12222.816 -9534.2529 3660.858 36000
400 254.88042 -11646.066 -9025.6878 5661.3674 36000
500 256.67901 -11247.388 -8608.5187 9173.6195 36000
Ts= 0.2
200 0 -12673.481 -12673.481 2546.0049 36000
300 0 -12739.355 -12739.355 2788.1116 36000
400 0 -12776.9 -12776.9 2852.939 36000
500 0 -12804.046 -12804.046 2854.771 36000
Ts= 2
200 -nan -nan -nan -nan 36000
300 -nan -nan -nan -nan 36000
400 -nan -nan -nan -nan 36000
500 -nan -nan -nan -nan 36000
My input’
units real
atom_style full
read_data mydata.in
group carbon type 1
group hydrogen type 2
group oxygen type 3
group water type 2 3
set group oxygen charge -0.8476
set group hydrogen charge 0.4238
set group carbon charge 0.0000
#pair_style dpd/tstat 300.0 300.0 10.0 34387
#comm_style brick
#comm_modify vel yes
#pair_style hybrid lj/cut/coul/long 10.0 10.0 tersoff
pair_style lj/cut/coul/long 10.0 10.0
pair_coeff 1 1 0.000000 0.0000 #lj/cut/coul/long
pair_coeff 1 2 0.00000 0.00000
pair_coeff 1 3 0.093627 3.1900
pair_coeff 2 2 0.000000 0.0000
pair_coeff 2 3 0.000000 0.0000
pair_coeff 3 3 0.155300 3.16900
#pair_coeff * * tersoff SiC_1994.tersoff NULL NULL C
bond_style harmonic
bond_coeff 1 529.581 1.0
angle_style harmonic
angle_coeff 1 37.95 109.47
fix force_zero carbon setforce 0.0 0.0 0.0
fix vel_zero carbon move linear 0.0 0.0 0.0 units lattice
velocity water create 300.0 34387 rot yes dist gaussian # for water
kspace_style ewald 1.0e-6
neighbor 2.0 bin
neigh_modify delay 0 every 10 check yes
reset_timestep 0
delete_atoms overlap 0.3 all all
minimize 1.0e-4 1.0e-6 100 100000
min_style cg
compute peatom all pe/atom
compute keatom all ke/atom
thermo 100
thermo_style custom step temp pe etotal press vol
thermo_modify norm no flush yes
fix ensemble_set water nvt temp 300.0 300.0 0.05
fix 2 water temp/rescale 100 300.0 300.0 10.0 0.05
fix spce_model water shake 0.0001 20 0 b 1 a 1
#fix 3 water addforce 0.0 0.0 1.0
variable end equal 1000
dump pos all custom ${end} pos_filename id element type q x y z
dump_modify pos format “%5d %5s %d %13.10f %17.12f %17.12f %17.12f”
dump_modify pos sort id
dump_modify pos element C HW OW
dump vel all custom ${end} vel_filename id element vx vy vz
dump_modify vel format “%5d %5s %18.15f %18.15f %18.15f”
dump_modify vel sort id
dump_modify vel element C HW OW
timestep 0.02
run 1000
A small part of my data file’
3450 atoms
2000 bonds
1000 angles
0 dihedrals
0 impropers
3 atom types
1 bond types
1 angle types
0 dihedral types
0 improper types
0.00 30.00 xlo xhi
0.00 30.00 ylo yhi
-5.00 35.00 zlo zhi
Masses
1 12.011000 # C
2 1.008000 # HW
3 15.999000 # OW
Atoms
1 1 1 0.000000 2.000000 2.000000 30.000000 # C JJC
2 1 1 0.000000 2.000000 4.000000 30.000000 # C JJC
3 1 1 0.000000 2.000000 6.000000 30.000000 # C JJC
4 1 1 0.000000 2.000000 8.000000 30.000000 # C JJC
5 1 1 0.000000 2.000000 10.000000 30.000000 # C JJC
451 1 3 -0.847600 24.346001 12.055000 24.049999 # OW JJC
452 1 2 0.423800 24.346001 12.872000 23.469999 # HW JJC
453 1 2 0.423800 24.346001 11.239000 23.469999 # HW JJC
454 1 3 -0.847600 9.512000 7.806000 20.660000 # OW JJC
455 1 2 0.423800 10.089000 7.806000 21.480000 # HW JJC
Bonds
1 1 451 452
2 1 451 453
3 1 454 455
4 1 454 456
5 1 457 459
Angles
1 1 452 451 453
2 1 455 454 456
3 1 458 457 459
4 1 461 460 462
5 1 464 463 465
