I have created a custom EAM style for energy evaluation only. I have duplicated pair_eam.h/cpp to pair_eam_test.h/cpp and deactivated the force addition. Otherwise, pair_eam_test works just like pair_eam.
I am running into an error when trying to implement eam_test on only-dissimilar atom types (in this code 9-11, but not 9-9 or 11-11). The following details how I tried to implement and troubleshoot this, and where I got stuck. I was checking if there is a more straightforward way to go about doing this. Help is greatly appreciated.
There were no errors with the following code, where eam_test was defined on atom types 9-9:
pair_style hybrid/overlay eam eam_test lj/cut/coul/long 10.0 10.0
pair_coeff 11 11 eam Cu_u3.eam
pair_coeff 9 9 eam_test Cu_u3.eam
However, this is my desired input and resulting error:
pair_coeff 9 11 eam_test Cu_u3.eam
ERROR: Incorrect args for pair coefficients (…/pair_eam_test.cpp:406)
Last command: pair_coeff 9 11 eam_test Cu_u3.eam
I traced this to the following block in pair_eam_test.cpp and commented out the error:
int count = 0;
for (int i = ilo; i <= ihi; i++) {
for (int j = MAX(jlo,i); j <= jhi; j++) {
if (i == j) {
setflag[i][i] = 1;
map[i] = ifuncfl;
atom->set_mass(FLERR,i,funcfl[ifuncfl].mass);
count++;
scale[i][j] = 1.0;
//if (count == 0) error->all(FLERR,“Incorrect args for pair coefficients”);
I then tried to run the desired block of code again and got a new error:
pair_coeff 9 11 eam_error Cu_u3.eam
ERROR: Incorrect args for pair coefficients (…/pair_hybrid_overlay.cpp:102)
Last command: pair_coeff 9 11 eam_ecam Cu_u3.eam
I then commented out the following error from pair_hybrid_overlay.cpp:
int count = 0;
if (none) {
setflag[i][j] = 1;
nmap[i][j] = 0;
count++;
} else if (styles[m]->setflag[i][j]) {
int k;
for (k = 0; k < nmap[i][j]; k++)
if (map[i][j][k] == m) break;
if (k == nmap[i][j]) map[i][j][nmap[i][j]++] = m;
setflag[i][j] = 1;
count++;
This was the final error, which came after the run command, and where I finally got stuck.
ERROR: Pair hybrid sub-style is not used (…/pair_hybrid.cpp:488)
Last command: run 1000
Again, I was checking if there was a more straightforward way of going about this without messing up the structure of the source code. Thank you for any help,
Anne
