Dear Lammps users/developer,
I am using TIP4P water model in a system including water and silicon.
The problem is that when Lammps starts to minimize the system, it stops. It stays in this step without any progress or error.
The initial part of input file is:
atom_style full
restart 10000 restart11 restart22
read_data TIP4P.data
set type 1 charge 0.520
set type 2 charge -1.040
set type 3 charge 0.000
bond_style harmonic
angle_style harmonic
dihedral_style none
pair_style hybrid lj/cut/tip4p/long 2 1 1 1 0.15 10.0 12.0 lj/cut/coul/long 10.0 12.0 meam/c
bond_coeff 1 100.0 0.9572
angle_coeff 1 10.0 104.52
pair_coeff * * meam/c library.meam Si Si.meam NULL NULL Si
pair_coeff 1 1 lj/cut/tip4p/long 0.00 0.00 #H-H
pair_coeff 1 2 lj/cut/tip4p/long 0.00 0.00 #H-O
pair_coeff 2 2 lj/cut/tip4p/long 0.006721 3.1536 #O-O
pair_coeff 2 3 lj/cut/coul/long 0.120878 2.6305 #Si-O
pair_coeff 1 3 lj/cut/coul/long 0.00 1.0475 #H-Si
kspace_style pppm/tip4p 1.0e-5
group SiSi type 3
group water type 1 2
minimize 1.00E-15 1.00E-15 1000000 10000000
neighbor 2.0 bin
timestep 0.001
fix 1 water shake 1.00E-06 100 0 b 1 a 1
velocity all create 498.15 4928459 rot yes dist gaussian
The initial part of data file also is:
37658 atoms
19644 bonds
9822 angles
0 dihedrals
0 impropers
3 atom types
1 bond types
1 angle types
0 dihedral types
0 improper types
-86.53004 86.53004 xlo xhi
-10.5651335 10.5651335 ylo yhi
-58.907505 58.907505 zlo zhi
Pair Coeffs
1 H
2 O
3 Si
Bond Coeffs
1 H-O
Angle Coeffs
1 H-O-H
Masses
1 1.008000 # H
2 15.999400 # O
3 28.084999 # Si
Atoms # full
1 1 2 -1.040000 14.856773 6.031134 41.662369 # O O
2 1 1 0.520000 14.075775 5.448134 41.771366 # H H
3 1 1 0.520000 14.515778 6.807135 41.171368 # H H
4 2 2 -1.040000 59.047783 -1.556866 50.970367 # O O
5 2 1 0.520000 59.602776 -2.161866 50.435364 # H H
6 2 1 0.520000 59.327782 -1.719866 51.894363 # H H
7 3 2 -1.040000 -37.135223 -6.559866 31.849365 # O O
and the last part of log file is:
Setting up cg style minimization …
Unit style : metal
Current step : 0
Per MPI rank memory allocation (min/avg/max) = 19.48 | 24.78 | 33.17 Mbytes
Step Temp E_pair E_mol TotEng Press
0 0 1.1557718e+16 1017.6889 1.1557718e+16 1.7192536e+17
I appreciate any comment to help.
Thank you.
If it is required, the initial pdb file that I used to add water to the system by packmol was:
HETATM 1 O 1 -2.688 2.013 0.000
HETATM 2 H 1 -3.582 1.611 0.000
HETATM 3 H 1 -2.076 1.248 0.000
CONECT 3 1
CONECT 2 1
CONECT 1 3 2
END
