Hi I have trouble installing matminer in windows with powershell. I copy the error message here:
Failed building wheel for pymatgen
Running setup.py clean for pymatgen
Failed to build pymatgen
mdf-forge 0.6.2 has requirement requests>=2.18.4, but you’ll have requests 2.9.1 which is incompatible.
mdf-toolbox 0.2.3 has requirement requests>=2.18.4, but you’ll have requests 2.9.1 which is incompatible.
mdf-toolbox 0.2.3 has requirement six>=1.11.0, but you’ll have six 1.10.0 which is incompatible.
networkx 2.1 has requirement decorator>=4.1.0, but you’ll have decorator 4.0.9 which is incompatible.
C:\Users\wusha\AppData\Local\Programs\Common\Microsoft\Visual C++ for Python\9.0\VC\Bin\amd64\link.exe /DLL /nologo /INCREMENTAL:NO /LIBPATH:c:\users\wusha\anaconda2\libs /LIBPATH:c:\users\wusha\anaconda2\PCbuild\amd64 /LIBPATH:c:\users\wusha\anaconda2\PC\VS9.0\amd64 /EXPORT:initcoord_cython build\temp.win-amd64-2.7\Release\pymatgen/util/coord_cython.obj /OUT:build\lib.win-amd64-2.7\pymatgen\util\coord_cython.pyd /IMPLIB:build\temp.win-amd64-2.7\Release\pymatgen/util\coord_cython.lib /MANIFESTFILE:build\temp.win-amd64-2.7\Release\pymatgen/util\coord_cython.pyd.manifest -Wl,–allow-multiple-definition
LINK : warning LNK4044: unrecognized option ‘/Wl,–allow-multiple-definition’; ignored
coord_cython.obj : warning LNK4197: export ‘initcoord_cython’ specified multiple times; using first specification
Creating library build\temp.win-amd64-2.7\Release\pymatgen/util\coord_cython.lib and object build\temp.win-amd64-2.7\Release\pymatgen/util\coord_cython.exp
coord_cython.obj : error LNK2019: unresolved external symbol round referenced in function __pyx_pf_8pymatgen_4util_12coord_cython_pbc_shortest_vectors
build\lib.win-amd64-2.7\pymatgen\util\coord_cython.pyd : fatal error LNK1120: 1 unresolved externals
error: command ‘C:\Users\wusha\AppData\Local\Programs\Common\Microsoft\Visual C++ for Python\9.0\VC\Bin\amd64\link.exe’ failed with exit status 1120
Command “c:\users\wusha\anaconda2\python.exe -u -c “import setuptools, tokenize;file=‘c:\users\wusha\appdata\local\temp\pip-install-cfehym\pymatgen\setup.py’;f=getattr(tokenize, ‘open’, open)(file);code=f.read().replace(’\r\n’, ‘\n’);f.close();exec(compile(code, file, ‘exec’))” install --record c:\users\wusha\appdata\local\temp\pip-record-iw3zkk\install-record.txt --single-version-externally-managed --compile --user --prefix=” failed with error code 1 in c:\users\wusha\appdata\local\temp\pip-install-cfehym\pymatgen\
anybody know how to solve this?
