I am simulating the adsorption of CH₄ and N₂ in a BN nanotube. CH₄ is modeled using a single-point LJ model, while N₂ follows the TraPPE force field, which consists of a 2LJ + 3-charge model. Specifically, CH₄ is represented as a single-point LJ model with one atom type, whereas N₂ is represented as a 2LJ + 3-charge model with two atom types.
I have a swnt.data
file that contains the structure of the BN nanotube. This file includes only two atom types corresponding to B and N. A portion of its contents is as follows:
# LAMMPS data file converted from XYZ
936 atoms
5 atom types
0.0 20.73053 xlo xhi
0.0 20.73053 ylo yhi
0.0 50.00000 zlo zhi
Masses
1 10.81
2 14.01
3 16.04 # CH4 (single-point LJ model)
4 14.01 # N atom in N2
5 1.0e-10 # Virtual site in N2 (mass = 0)
Atoms
1 1 1 0.4000 16.58441 8.29221 1.20490
2 2 1 -0.4000 16.45831 9.73271 1.20490
3 1 1 0.4000 16.30191 10.43841 2.45730
4 2 1 -0.4000 15.80731 11.79721 2.45730
5 1 1 0.4000 15.47351 12.43831 1.20490
6 2 1 -0.4000 14.64401 13.62281 1.20490
7 1 1 0.4000 14.15571 14.15571 2.45730
The LAMMPS input script is as follows:
# --------------------- Initialization ---------------------
units real
atom_style full # Use full to support charge and molecule ID
boundary s s p # Non-periodic in x, y; periodic in z
# --------------------- Read BN Nanotube ---------------------
read_data swnt.data # Directly load BN nanotube structure
# --------------------- Define Regions ---------------------
region nanotube cylinder z 10.365 10.365 8.29221 0 50 units box
region CH4_ads_region cylinder z 10.365 10.365 8.29221 0 50 units box
region N2_ads_region cylinder z 10.365 10.365 8.29221 0 50 units box
# --------------------- Force Field Parameters ---------------------
pair_style lj/cut/coul/cut 12.0 # 12 Å cutoff
pair_modify mix arithmetic
# No interaction between BN atoms
# Interactions between adsorbates and BN
pair_coeff 1 3 83.96 3.591 # B-CH4
pair_coeff 2 3 104.18 3.548 # N-CH4
pair_coeff 1 4 41.48 3.382 # B-N2
pair_coeff 2 4 51.21 3.338 # N-N2
pair_coeff 1 5 0.0 0.0 # B-Virtual Site
pair_coeff 2 5 0.0 0.0 # N-Virtual Site
# Adsorbate-adsorbate interactions
pair_coeff 3 3 148.0 3.73 # CH4-CH4
pair_coeff 4 4 36.0 3.31 # N-N (TraPPE)
pair_coeff 5 5 0.0 0.0 # Virtual site no interactions
# --------------------- BN Nanotube Charges ---------------------
set type 1 charge 0.4 # B atoms
set type 2 charge -0.4 # N atoms
# --------------------- Define Molecular Templates ---------------------
molecule CH4_mol CH4_molecule.txt
molecule N2_mol N2_molecule.txt
# --------------------- GCMC Adsorption Simulation ---------------------
fix gcmc_CH4 all gcmc 1000 10000 10000 3 29494 298.0 0.1 region CH4_ads_region fugacity 10.0 mol CH4_mol
fix gcmc_N2 all gcmc 1000 10000 10000 4 54321 298.0 0.1 region N2_ads_region fugacity 10.0 mol N2_mol
# --------------------- Simulation Control ---------------------
thermo 1000
thermo_style custom step temp press pe ke etotal density vol
dump mydump all atom 1000 dump.lammpstrj
run 500000
The CH4_molecule.txt
file is as follows:
# CH4 molecule (single-point LJ model)
1 atoms
Atoms
1 3 0.0 0.0 0.0 0.0
The N2_molecule.txt
file is as follows:
# TraPPE N2 molecule definition (corrected version)
3 atoms # Now includes 2 N atoms + 1 virtual site
1 bond
3 charges
Atoms
1 4 -0.482 0.0 0.0 -0.55 # First N atom with partial charge
2 4 -0.482 0.0 0.0 0.55 # Second N atom with partial charge
3 5 0.964 0.0 0.0 0.0 # Virtual site with +0.964 e charge
Bonds
1 1 2 # N-N bond
Error Message
Upon running LAMMPS, I encountered the following error:
LAMMPS (29 Aug 2024 - Update 1)
Reading data file ...
orthogonal box = (0 0 0) to (20.73053 20.73053 50)
reading atoms ...
936 atoms
special bond factors lj: 0 0 0
special bond factors coul: 0 0 0
0 = max # of 1-2 neighbors
0 = max # of 1-3 neighbors
0 = max # of 1-4 neighbors
1 = max # of special neighbors
special bonds CPU = 0.000 seconds
read_data CPU = 0.004 seconds
Setting atom values ...
936 settings made for charge
0 settings made for charge
ERROR on proc 0: Unknown section 'Atoms' in molecule file
(src/molecule.cpp:664)
Last command: molecule CH4_mol CH4_molecule.txt
