Hello everyone,
Thank you Axel for helping me. I resolved those issues. However, when I am simulating with 100 molecules of water, the simulation works fine. I checked from 3, 10, 50, 100 molecules. But when I increased to 120 molecules, the output shows NAN in all thermodynamic output in every timestep extracted from thermo. I know I can have several issues here. But why it would work for 100 molecules but not with 120 molecules?The box dimensions are 22x22x22 angstrom. timestep is 1 fs, Tdamp=100*timestep. I have changed parameters in neigh_modify also. Here is my input file:
SPC water
echo screen
log debug.log
units real
neighbor 2.0 bin
neigh_modify delay 0 every 1 one 10000 check yes
atom_style full
bond_style harmonic
angle_style harmonic
dihedral_style none
improper_style none
pair_style lj/cut/coul/cut 9.0 9.0
read_data water_diff.data
pair_modify mix arithmetic tail yes
group hydrogen type 1
group oxygen type 2
group water type 1 2
set group oxygen charge -0.82
set group hydrogen charge 0.41
pair_coeff 1 1 0.0 0.0
pair_coeff 1 2 0.0 0.0
pair_coeff 2 2 0.1553 3.166
bond_coeff 1 0.0 1.0
angle_coeff 1 0.0 109.47
velocity water create 300.0 12345 dist gaussian
fix 1 water shake 1.0e-8 100 0 b 1 a 1
fix 2 water npt temp 300.0 300.0 100.0 iso 1.01325 1.01325 50
Tdamp=100*timesteps
variable timesteps equal 1 #femtosecond
timestep ${timesteps}
thermo 50
thermo_style custom step temp press vol etotal ke pe evdwl ecoul elong
write_data data.spc_out pair ij
dump 1 all xyz 1 spc.xyz
#dump 2 all image 100 dump.*.jpg type type
run 1000
SPC water
echo screen
log debug.log
units real
neighbor 2.0 bin
atom_style full
bond_style harmonic
dihedral_style none
improper_style none
group oxygen type 2
Tdamp=100*timesteps
thermo 50
run 1000
Hello everyone,
Thank you Axel for replying to me. I changed the input file for SPC model to
a low density water box. Now, I am having numeric index out of bound errors.
I defined types of atoms, bonds, angles, impropers and dihedrals in the data
file, and the corresponding coefficients are in the input file. I don’t
understand where my atom IDs might be wrong because there’s only 9 atoms in
the box. Can someone please help me? I have copied both input file and data
file for you to see.
look closely at the output to the screen and note the line in the
input where the error occurs.
it has nothing to do with atom indices, but bond (and angle) type.
your data file has only one type (1), but you are setting parameters
for type 2. that clearly means the type index is out of bounds.
SPC water box (3 molecules)
SPC water
echo screen
log debug.logunits real
neighbor 2.0 bin
#neigh_modify delay 0 every 1 one 10 check yes
neigh_modify delay 5boundary p p p
atom_style full
bond_style harmonic
dihedral_style none
improper_style nonepair_style lj/cut/coul/cut 9.0 9.0
read_data data.lowdensity
pair_modify mix arithmetic tail yesgroup hydrogen type 1
group oxygen type 2
group water type 1 2set group oxygen charge -0.82
set group hydrogen charge 0.41pair_coeff 1 1 0.0 0.0
pair_coeff 2 2 0.1553 3.166bond_coeff 2 0.0 1.0
angle_coeff 2 0.0 109.47velocity water create 300.0 12345 dist gaussian
fix 2 water npt temp 300.0 300.0 100.0 iso 1.01325 1.01325 500timestep 1.0
thermo 50
thermo_style custom step temp press vol etotal ke pe evdwl ecoul elongdump 1 all xyz 1 spc.xyz
run 10000DATA file:
LAMMPS data file. CGCMM style. atom_style full generated by VMD/TopoTools
v1.5 on Tue Dec 01 16:55:25 CST 2015
9 atoms
6 bonds
6 angles
0 dihedrals
0 impropers
2 atom types
1 bond types
1 angle types
0 dihedral types
0 improper types
