Hello friends,
I compiled lammps with pair_allegro and tested the input file :
atom_style charge
set newton on for pair_allegro (off for pair_nequip)
newton on
read_data quartz.lammps
if you want to run a larger system, simply replicate the system in space
replicate 3 3 3
allegro pair style
pair_style allegro3232
pair_coeff * * SiO-deployed.path O Si
mass 1 15.999
mass 2 28.0855
velocity all create 300.0 1234567 loop geom
neighbor 1.0 bin
neigh_modify delay 5 every 1
timestep 0.001
thermo 10
nose-hoover thermostat, 300K
fix 1 all nvt temp 300 300 $(100*dt)
compute rdf and average after some equilibration
#comm_modify cutoff 7.0
compute rdfall all rdf 1000 cutoff 5.0
compute rdfall rdf 1000 1 1 1 2 2 2 # For Si-Si, Si-O, O-O
compute rdfall all rdf 100 1 1 1 2 2 2 # For Si-Si, Si-O, O-O
#fix 2 all ave/time 1 2500 5000 c_rdfall[*] file SiO.rdf mode vector
compute myRDF all rdf 100 1 1 1 2 2 2 # For Si-Si, Si-O, O-O
Fix to output RDF data to a file, referencing the correct compute ID
fix 2 all ave/time 100 1 100 c_myRDF[1] c_myRDF[2] c_myRDF[3] file rdf_output.dat mode vector
run 5ps
run 5000
The job kept terminating with the message:
Exception: Argument passed to at() was not in the map.
Abort(1) on node 0 (rank 0 in comm 0): application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0
Please i need your help in fixing this problem.
