Hi everyone,
I hope you are fine.
I needed to use GCMC to study the adsorption. As I understand it, only one core can be used, which is very time-consuming.
Based on what I read in the Mail list, I decided to install LAMMPS via GPU to speed up the program.
I’m using Ubuntu 20.04 LTS, NVIDIA driver 450.57 for GK208B [GeForce GT 710], and CUDA 11.0.1.
I installed LAMMPS (21 Jul 2020) with Cmake and ./lmp -h gives:
Invalid MIT-MAGIC-COOKIE-1 key
Large-scale Atomic/Molecular Massively Parallel Simulator - 21 Jul 2020
Git info (master / patch_21Jul2020-30-g41535d8de)
Usage example: ./lmp -var t 300 -echo screen -in in.alloy
List of command line options supported by this LAMMPS executable:
-echo none/screen/log/both : echoing of input script (-e)
-help : print this help message (-h)
-in filename : read input from file, not stdin (-i)
-kokkos on/off … : turn KOKKOS mode on or off (-k)
-log none/filename : where to send log output (-l)
-mpicolor color : which exe in a multi-exe mpirun cmd (-m)
-nocite : disable writing log.cite file (-nc)
-package style … : invoke package command (-pk)
-partition size1 size2 … : assign partition sizes (-p)
-plog basename : basename for partition logs (-pl)
-pscreen basename : basename for partition screens (-ps)
-restart2data rfile dfile … : convert restart to data file (-r2data)
-restart2dump rfile dgroup dstyle dfile …
: convert restart to dump file (-r2dump)
-reorder topology-specs : processor reordering (-r)
-screen none/filename : where to send screen output (-sc)
-suffix gpu/intel/opt/omp : style suffix to apply (-sf)
-var varname value : set index style variable (-v)
OS: Linux 5.4.0-42-generic on x86_64
Compiler: GNU C++ 9.3.0 with OpenMP 4.5
C++ standard: C++11
MPI v3.1: Open MPI v4.0.3, package: Debian OpenMPI, ident: 4.0.3, repo rev: v4.0
.3, Mar 03, 2020
Active compile time flags:
-DLAMMPS_GZIP
-DLAMMPS_PNG
-DLAMMPS_JPEG
-DLAMMPS_FFMPEG
-DLAMMPS_SMALLBIG
sizeof(smallint): 32-bit
sizeof(imageint): 32-bit
sizeof(tagint): 32-bit
sizeof(bigint): 64-bit
Installed packages:
ASPHERE BODY COLLOID CORESHELL DIPOLE GPU KOKKOS KSPACE MANYBODY MC MISC MOLECULE OPT RIGID USER-DRUDE USER-MEAMC USER-OMP
I ran a file containing the NPT ensemble once through the CPU and again through the GPU. The result was as follows:
Using CPU took 7 s while using GPU took 54s. (Which is very strange!)
I also ran the GCMC file that was placed in the GitHub by Mr. Axel Kohlmeyer. In both cases of using GPU and CPU, only one core used and the running speed of the program is as follows:
Using CPU took 7 s while using GPU took 17s. (Related files are attached.)
The following error appears when I use more than one core:
Invalid MIT-MAGIC-COOKIE-1 keyLAMMPS (21 Jul 2020)
OMP_NUM_THREADS environment is not set. Defaulting to 1 thread. (src/comm.cpp:96)
Lattice spacing in x,y,z = 5.0000000 5.0000000 5.0000000
Created orthogonal box = (0.0000000 0.0000000 0.0000000) to (10.000000 10.000000 10.000000)
1 by 2 by 2 MPI processor grid
Read molecule template co2mol:
1 molecules
3 atoms with max type 2
2 bonds with max type 1
1 angles with max type 1
0 dihedrals with max type 0
0 impropers with max type 0
Created 24 atoms
create_atoms CPU = 0.002 seconds
24 atoms in group co2
create bodies CPU = 0.000 seconds
8 rigid bodies with 24 atoms
1.1600000 = max distance from body owner to body atom
dynamic group carbon defined
dynamic group oxygen defined
Ewald initialization …
using 12-bit tables for long-range coulomb (src/kspace.cpp:330)
G vector (1/distance) = 0.23411209
estimated absolute RMS force accuracy = 0.033665616
estimated relative force accuracy = 0.000101383
KSpace vectors: actual max1d max3d = 16 2 62
kxmax kymax kzmax = 2 2 2
gcmc.rar (8.81 KB)
npt.rar (34 KB)
