Dear Lammps users,
When using compute chunk/atom command, I found if I set the “bound” value in x y z dimension each, like:
bound x 4 12 y 4 12 z 4 12 units box
it will give me an error as “Illegal compute chunk/atom command (…/compute_chunk_atom.cpp:227)”
I checked the source code and it seems it only allows to define bound in only one dimension. I tried with “bound x 4 12 units box” and all work well. I’m not sure if this is the problem.
Thank you for your help!
Dear Lammps users,
When using compute chunk/atom command, I found if I set the "bound" value
it will give me an error as "Illegal compute chunk/atom command
(../compute_chunk_atom.cpp:227)"
only one dimension. I tried with "bound x 4 12 units box" and all work
well. I'm not sure if this is the problem.
that is not correct. you have not read the documentation correctly. it
says explicitly:
It can be used one or more times to limit the extent of bin coverage in a
specified dimension, i.e. to only bin a portion of the box.
thus for *each* limit, you have to use: bound <dim> <lo> <hi>
axel
