بسم الله الرحمن الرحيم
Thanks for your replay.
I have another question which is:
Are REAX and REAXC packages do the same work ? which are better ?
I compiled LAMMPS using REAXC and REAX with MSCG, but there is a problem that there is a variable defined as a double in REAXC and as a float in MSCG ( the same variable ) and this issue terminated the compilation process, I solved it by change float to double, did this affect the results of these packages ?
Alaa Murrar
