Dear Developers/Users,
I am a beginner in using Lammps. I am trying to thermally equilibrate a silicon nanostructure at 300 K. I am using Tersoff potential and Stillinger-Waber potential (distributed with the LAMMPS package). The structure is periodic in X,Y-Z direction and clamped in X direction (by setting force on the first layer of unit cell equal to zero). The structure is free to vibrate in X direction.
The problem I have is that during heating using NVT ensemble (in 20 ns) to reach 300 K from 1 K, (timestep 1fs) few atoms escape from the structure and move towards the wall of the box. I have tried different TDamp for the thermostat (10 fs,100 fs,1000 fs) and also tried using timestep of 0.5 fs, but the problem persists. Can anyone shed some light on this problem. I have searched the mail-list but could not figure out a solution.
The script I use is the following
atom_style atomic
lattice diamond 5.43 orient x 1 0 0 orient y 0 1 0 orient z 0 0 1 &
region box block 0 18 -4 4 -4 4
create_box 1 box
create_atoms 1 box
mass 1 28.055
pair_style tersoff
pair_coeff * * Si.tersoff Si
timestep 0.001
region RDel block 13 18 -4 4 -4 4
group gRDel region RDel
delete_atoms group gRDel
region LFix block 0 1 -4 4 -4 4
group gLFix region LFix
region NFix block 1 13 -4 4 -4 4
group gNFix region NFix
region RFix1 block 12.5 13 -4 4 -4 4
thermo 1
thermo_style custom step temp pe vol pxx pyy pzz
fix f1 gLFix setforce 0 0 0
fix nveFix gLFix nve
velocity gNFix create 1 1005698 mom yes rot yes dist gaussian
fix NVT gNFix nvt temp 1 300 0.1
run 20000000
fix nvt0 gNFix nvt temp 300 300 0.1
run 2000000
Sankha Mukherjee
