Just running a simple test, when I tried to run the below code with the latest LAMMPS version (11Nov13), the simulation was terminated by the: ERROR: Invalid fix style (…/modify.cpp:714). This error is related with the command: fix 1 sample rigid single. However, with an older LAMMPS version (15Jan10) the same code run well. The detailed running process can be found in attached document. Therefore, I am wondering is there a bug with the fix rigid command for the latest LAMMPS version, or there is something wrong within my code? Thanks.
Junjie
--------code------
atom_style atomic
lattice fcc 3.52
region box block 0 10 0 10 0 10
create_box 1 box
region sample sphere 5 5 5 3
create_atoms 1 region sample
group sample region sample
pair_style eam
pair_coeff * * Ni_u3.eam
neighbor 2.0 bin
neigh_modify delay 5
timestep 0.001
run 100
error.txt (1.48 KB)
in.shear (336 Bytes)
