Hello Dear
I going to use gravity(9.8) in my simulation. I’m simulating Argon with lj unit. In this simulation, Argon is used as a Lennard-Jones fluid with the following potential parameters:
Energy parameter (epsilon) =1.67*10^-21 J
Length parameter (sigma) =3.4*10^-10 M
Mass=6.63*10^-26 Kg
I tried to use unitless gravity with this formula:
Unitless gravity= (gravitysigmamass)/epsilon
ð Unitless gravity = gravity*(1.35*10^ -14)
Then I used command below for gravity:
fix G flow gravity 1.323*10^-13 vector 0 -1 0
Are unitless formulas and command true?
Thanks for your help
Hello Dear
Mass=6.63*10^-26 Kg
Unitless gravity= (gravity*sigma*mass)/epsilon
you have to test this yourself. this is not the "please check my math"
mailing list.
apart from that. what is the point to add such a tiny force?
