Thanks for all your assistance
but when I want to patch the file, it fails
is the version I used causes the problem ? (7Dec15 and 16Feb16 i use )
following is the logout
{patching file lib/gpu/Makefile.linux
Hunk #1 FAILED at 7.
1 out of 1 hunk FAILED – saving rejects to file lib/gpu/Makefile.linux.rej
patching file lib/gpu/lal_base_three.cpp
patching file lib/gpu/lal_base_three.h
patching file lib/gpu/lal_neighbor.cpp
patching file lib/gpu/lal_neighbor.h
patching file lib/gpu/lal_sw.cpp
Hunk #5 FAILED at 192.
Hunk #6 succeeded at 225 (offset -2 lines).
1 out of 6 hunks FAILED – saving rejects to file lib/gpu/lal_sw.cpp.rej
patching file lib/gpu/lal_sw.cu
patching file lib/gpu/lal_sw.h
patching file lib/gpu/lal_tersoff.cpp
patching file lib/gpu/lal_tersoff.cu
Hunk #1 succeeded at 611 with fuzz 1 (offset 14 lines).
Hunk #2 succeeded at 687 (offset 20 lines).
Hunk #3 succeeded at 841 with fuzz 1 (offset 18 lines).
Hunk #4 succeeded at 917 (offset 24 lines).
can’t find file to patch at input line 1456
Perhaps you used the wrong -p or --strip option?
The text leading up to this was:
