Problem with my MSD plot
Dear lammps user
I tried to calculate diffusion coefficient thus I plotted MSD vs Time, so I used "fix Lithium_MSD Sodium ave/time 10 10 100 c_msd[1] c_msd[2] c_msd[3] c_msd[4] “.
My pair style is " lj/cut/coul/long” and the time step is 0.0001.After 30000000 run, the result was confusing me! due to this plot, could you help me to understand in which part of my work is wrong?
pair_style lj/cut/coul/long 14 14
read_data NaZr2P3O12.data
kspace_style ewald 1.0e-5
kspace_modify gewald 1.0e-5
fix MM all box/relax iso 0.0 vmax 0.001
min_style cg
minimize 1.0e-12 1.0e-12 10000 10000
unfix MM
velocity all create 700 2547321 mom yes rot yes
run 200000
unfix NPT
fix NPT all npt temp 700.0 700.1 0.01 x 0 1 1 y 0 1 1 z 0 1 1
run 30000000
Have you tried visualizing the trajectory? This MSD plot looks like it represents a solid or glass.
Can we see your full input script? This snippet is missing a lot of information.
Sure!
My structure from NASICONs families.
atom_style charge
timestep 0.0001
atom_modify map array sort 0 0.0
neighbor 3.0 nsq
pair_coeff 1 1 0.00844 3.541 #O_O
pair_coeff 1 2 0.01083 3.844 #O_P
pair_coeff 1 3 0.00503 3.332 #O_Zr
pair_coeff 1 4 0.00331 3.508 #O_Na
pair_coeff 2 2 0.0139 4.147 #P_P
pair_coeff 2 3 0.0064 3.635 #P_Zr
pair_coeff 2 4 0.0042 3.811 #P_Na
pair_coeff 3 3 0.003 3.124 #Zr_Zr
pair_coeff 3 4 0.001 3.299 #Zr_Na
pair_coeff 4 4 0.0013 3.475 #Na_Na
min_style cg
unfix MM
thermo 1000
run 200000
unfix NPT
compute msd Sodium msd com yes
fix Lithium_MSD Sodium ave/time 10 10 100 c_msd[1] c_msd[2] c_msd[3] c_msd[4] file average-msd.txt
thermo 10000
thermo_style custom step temp pe c_msd[1] c_msd[2] c_msd[3] c_msd[4] etotal pxx pyy pzz lx ly lz
log result.txt
dump 1 all custom 100000 dump.lammpstrj id type x y z
run 3000000
And far as I can tell, your input looks fine, although I think the second NPT should be x 1 1 1, etc. instead of x 0 1 1. Same for the temperature (700.0 instead of 700.1).
I would visualize the system to make sure that it’s in the state you expect. That MSD plot looks like your system may be glassy.
Thanks a lot, I really appreciate
Dear,
Warm greetings. Can you please share the data file for NaZr2(PO4)3 with me? Also, could you provide me with the bibliographic reference for the potential coefficient values? Thank you.
Sincerely,
Edgar Matallana
[email protected]
