Dear All,
I am trying to run some NEB calculations with LAMMPS. I am using the 1-Feb-2014 version. My input script is below. When I run the NEB calculation I get the following error message:
ERROR: Cannot use NEB with atom_modify sort enabled
What I don’t understand is why I am getting this, since I am using the command atom_modify map array sort 0 0.0
Am I missing something?
D
final.xyz (1.14 MB)
STO.in (1.7 KB)
Dear All,
What I don't understand is why I am getting this, since I am using the command atom_modify map array sort 0 0.0
whenever you encounter some inconsistent behavior in LAMMPS, please
always also test the latest version. perhaps you have run into a bug
that has since been fixed. at least on my laptop your input seems to
be working, but i cannot say if this is by chance or by design.
thanks,
ok, i've dug a little deeper and can confirm, that you have found a
bug in LAMMPS.
since the problem is caused by the replicate command you can work
around it until the proper bugfix in included by putting:
atom_modify sort 0 0.0
*after* the replicate line.
thanks,
